32-bit linux or windows UZB update tool
neillans
Post by neillans »
Is there a version of the UZB update tool that can be used on 32bit linux or Windows command line, without needing to mess about installing the full controller (which fails to load the update portion for me anyway)
Re: 32-bit linux or windows UZB update tool
neillans
Post by neillans »
Any chance of getting https://z-wave.me/download/ZMESerialUpdater compiled as ARM to allow it to run on Raspberry Pi's?
It's also a 64-bit compilation looking at the metadata:
./ZMESerialUpdater: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=373ec5dee826653796e927ac3d65c9a8ec7db9da, stripped
Yes, it is for Linux x64. On Pi you are better to use Z-Way with the API
neillans
Post by neillans »
Any reason? Any chance the code can be released? I'd be willing to do a 32bit / arm port and a windows version ...
Installing z-way just for this is a crazy requirement and it honestly just doesn't work half the time (end up with the firmware page no responding)
neillans
Post by neillans »
I've setup a 64-bit Linux box to run the script, however, when I run it all I get is a constant stream of --> and thats it ....
i.e. According to docs this should print version info
./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0
Z-Wave Serial API Tool
Version:LWE0.9
by Z-WAVE>ME
etc until terminated
This is a try to connect. Looks the port is not correct or the user is not in dialout group
neillans wrote:
13 Aug 2019 09:33
Now https://z-wave.me/download/ZMESerialUpdater.tgz contains x64 and ARM versions (for Raspberry Pi)
Now it is possible to use Z-Way for this:
We have just made a beta for Z-Way v3.0.3: https://storage.z-wave.me/z-way-server/ ... 3-beta.msi
We are testing it to make a release this week. You can also test. Make sure to have a backup of the Z-Way folder before you install it
Currently no Google Home/Alexa and no WebSockets, but soon we add them too.
