I upgraded my Z-Way (RPi B+ & Razberry, Raspbian Stretch) from 2.3.8 to 3.0.0. following the instructions.
The upgrade worked in general. When logging into the web-frontend I realized that all my devices where missing. Only software elements were still available.
I performed a Restore incl. Z-Wave Network from a cloud backup and all devices were back again. So far so good.
Then I wanted to change a rule (Automation -> Rules -> select a rule for modifiying). Surprisingly in Assigned conditions of IF section it showed me only "Device not available"(Advanced settings activated). There were also no devices for selection. Available are only "Time condition", "Nested condition" and "2 Device comparision".
In the THEN section it showes me "Device not available (ZWayVDev_zway_5-0-37)" (internal Z-WAY name, changed to AEOTEC Micro Switch G2).
Also no device available for selection.
But the ruels are still working anyway. (I didn´t change the rules or saved them, for sure)
Can someone help me?
Regards
Joachim
Rules & Scenes corrupted after upgrade to 3.0.0
- Unbenannt.jpg (85.52 KiB) Viewed 5791 times
Re: Rules & Scenes corrupted after upgrade to 3.0.0
Hi to whom it may concern,
I decided to test a factory reset and a restore (backup from 2.3.8) then.
This worked for me - with one little restriction.
The rules are working and z-way shows the assigned devices and also more devices to choose from. Fine so far!
Restriction is:
When I open the RULES section I got a pop-up stating: "SmartHome UI" "There are Logical Rules or If -> Then's to transform."
With Options: "TRANSFORM" or "CANCEL".
When I choose TRANSFROM nothing happens (or seems to happen). I even see no rules.
When I choose CANCEL it shows me all my rules.
It is annoying to click always CANCEL.
Is there a solution for ths remaining issue?
Regards
Joachim
Restriction is:
Regards
Joachim
I think that's a bug in 3.0.0 along with some other UI bugs, raspberry reboot solved the problem for me and as I don't need to adjust scenes often not a big deal, beside that 3.0.0 works very good.
We have recently found a bug in rules: if alarm devices are present, the UI shows no available devices. May be you see same case. There is a workaround and we will fix it soon
Are there any news?
I do not see any devices in "Automation" more - only in "Heating Control" they will be shown....
Thanks!
Michael
This is fixed now in the development tree.
