Wrong information in update window
donquixote0906
Post by donquixote0906 »
under management -> firmware update the correct firmware 3.0.0 is displayed.
When i open the firmware update window the firmware is 2.8.0 and it is possible to
update version 3.0.0.
Is it a bug?
platypus
Re: Wrong information in update window
Post by platypus »
To me it looks like a bug. I can't see any version in the firmware update window. It shows:
prm_fw_curver: Err(1.18.3): main.c: 501: The spawned process 'get_z-way_version.sh' has exited with code 1 and says:
otverber
Post by otverber »
Same here:
Firmware Update
The current firmware version is
however its now possible to upgrade to: update to latest (v3.0.1 )
after 2 clean reinstallations of v3.0.0 in half a week i will not try this update until confirmed that its safe..
PNinBB
Post by PNinBB »
I have exactly the same result as 'otverber'. What to do to avoid that and return to normal ?
We will fix it
z-wavettaja
Post by z-wavettaja »
PNinBB wrote:
05 Oct 2019 12:24
:arrow: same results here. Luckily got my system running again after this, which I found on this forum elsewhere:
sudo apt-get --reinstall install -o Dpkg::Options::="--force-confmiss" -o Dpkg::Options::="--force-confold" -y z-way-server
