suggested Update to 3.0.1 fails, Z-Way installation corrupt!
michap
Contact:
Post by michap »
I tried today an uprade to new firmware (from 3.0.0 to 3.0.1) - was suggested in interface.
Upgrade finished with a message about a disabled webinterface (?) (do not remember in detail).
I have seen that still 3.0.0 was running and wanted to restart Z-Way - but in /etc/init.d/ was no more z-way-server command :!:
So a restart would not be possible more.
I have killed the running process and tried to reinstall manual via console the current version.
Had to use apt-get remove and purge for removing old app. (there were no productive data inside, it is a review enviroment only...)
After that was installed the current version at new - but again without the start/stop script - AND: without any files in /opt folder !!
Have no running Z-Way in this time - any idea??
So I suggest to be very patient while updating, not sure why this happen.
Michael
RPJacobs
Re: suggested Update to 3.0.1 fails, Z-Way installation corrupt!
Post by RPJacobs »
I have the same problem....
CYberF0x
Post by CYberF0x »
I have the same problem, more or less. Upgrade to Raspbian GNU/Linux 9 (stretch) and manually copying the config.xml from an old update gets the z-way-server to start. but all devices are gone! I have also no start script and many things missing.
root@raspberrypi:/opt/z-way-server# ./z-way-server
Z-Way version v3.0.0 from 2019-07-18 02:47:11 +0300 (build fabbd8c917ba3564c3cee86f3baca2e04da1892f)
Module modskininstaller.so loaded
Module modinstaller.so loaded
Module modsockets.so loaded
Module modhomekit.so loaded
Module modcrypto.so loaded
Module modiconinstaller.so loaded
Module modzbw.so loaded
Module modnotification2ext.so loaded
Module modzwave.so loaded
Module moddhs.so loaded
Module modhttp.so loaded
Module modws.so loaded
Module modenocean.so loaded
cat: /etc/z-way/box_type: No such file or directory
Michael74
Post by Michael74 »
Can confirm similar issue here.
Had to roll-back to 2.3,8 to get all working again.
michap
Contact:
Post by michap »
Michael74 wrote:
13 Oct 2019 20:12
is working with
wget -q -O - razberry.z-wave.me/install/v2.3.8 | sudo bash
... but this cannot be the solution ;)
@PoltoS - is there a right solution in sight?
micky1500
Post by micky1500 »
I did the same upgrade.
After reboot... nothing running from z-way.
Tried a forced upgrade in BASH.. failed.
I had backups, so uninstalled and started fresh.
sudo apt-get remove z-way-server
now working on 3.0.1
michap
Contact:
Post by michap »
micky1500 wrote:
13 Oct 2019 20:38
I made the same multiple times today - no success.
I think you have not removed the old files from /opt/z-way-server that's why the installation made it work again (with existing files).
equathza
Post by equathza »
Upgrade to 3.0.1 with:
# wget https://storage.z-wave.me/z-way-server/z-way-3.0.1_armhf.deb
# sudo dpkg -i z-way-3.0.1_armhf.deb
-> A fellow Z-way user running a network of 50+ devices
michap
Contact:
Post by michap »
@equathza: Thanks, yes, it will work.
But the main problem is that the Upgrade via UI failed - this will be used by most users.
Second try of users (who want to work with shell) will be the documented upgrade link above - and it is not working too.
I think there is/was a mistake in the install script, and this should be fixed.
Anyway - thanks for your solution, it can help to upgrade ;)
Michael
3.0.1 is only for Buster. On Stretch 3.0.0 is the latest. You can explicitly install it, but the script will reinstall v3.0.0
