SmartHome UI Error
nkraus
SmartHome UI Error
Post by nkraus »
I have two raspberry pi with zwave.me. One with the UZB and one with razperry HAT. The one with the HAT always tells me the error Smathome UI Error - unable to update data, wenn I want to add a device to dashboard, but it works and everything is added to dashboard. The one with the UZB does not have the problem. So what is the problem and is there any solution?
platypus
Re: SmartHome UI Error
Post by platypus »
I use a RaZberry HAT and I’ve noticed this behavior plenty of times but in my case it seems to happen randomly. Sometimes it works, sometimes not. I assumed that to log off and log in again helps. A new installation of z-way v3.0.0 on a clean “Strech” image did not help.
We have also noticed the issue, will check it.
Fixed. https://github.com/Z-Wave-Me/zwave-smar ... 683a5590bc
Will be part of the next release.
