Compatibility with GE Devices
Inco
Post by Inco » 13 Mar 2013 15:19
I see from the technical spec that the antenna can work 868/908 bands. However when I go to EU sellers they only mention 868. Is it possible to enable 908 band in the EU version (I know its licensed but I would do tests in a closed lab).
Also, assuming I can use the 908 band, would the RaZberry be compatible with GE Devices such as
http://www.securitystoreusa.com/Caddx-C ... szwam1.htm
Thanks very much for the info.
The manual is common for both
Post by PoltoS » 13 Mar 2013 15:19
The manual is common for both version. Chips are different, so it is not possible to use EU module with US
