Thermostat
pacaj2am
Thermostat
Post by pacaj2am » 21 Mar 2013 00:47
I just wonder howto change thermostat setpoint for my thermostat. I would assume, that command:
http://raspberrypi.lan:8083/ZWaveAPI/Ru ... figSet(27)
would change the value to 29 Degrees. But I receive error. I tried both userSet and configSet.
Could you, please, help?
Thank you
Jan
Which thermostat do you have
Post by pz1 » 21 Mar 2013 00:47
Which thermostat do you have? In case it is a Danfoss Living Connect, remember the temperature setting range is 4-28 Centigrade.
pacaj2am
yes
Danfoss... Oops... I spent several hours... :-(
pacaj2am
I'm still not sucessfull
Even with lower temperature, that is in range. :-(
the method is called Set, not
Post by PoltoS » 21 Mar 2013 00:47
the method is called Set, not configSet. Please check the manual on the razberry.zw-ave.me site.
pacaj2am
i found solution... :-)
razberry.lan:8083/ZWaveAPI/Run/devices[5].instances[0].commandClasses[67].Set(1,23)
this sets the Danfoss Valve to 23°C... Even 22.5°C works...
pacaj2am
I have still question
null is returned. Is that correct?
Yes, it is. The function
Yes, it is. The function returns nothing if succeed and an exception is case of error
pacaj2am
ok, super... i will bring
ok, super... i will bring decision logic on it...
thank you
jan
