Debugger for Z-Way JavaScript
Post by PoltoS » 23 May 2014 21:18
We are happy to introduce Z-Way JavaScript engine debugger tool based on v8 debugger.
How to use it?
Install v1.7.1-rc1 (the only difference compared to v1.7.0 is the debugging available).
Install Node Inspector on your PC or on Raspberry Pi.
Add this line just after another "export" in /etc/init.d/z-way-server:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/z-way-server/libs
export V8_DEBUG=yes
Restart Z-Way:
/etc/init.d/z-way-server restart
If Node Inspector is on your local manchine, make a tunnel to Raspberry Pi port:
ssh -N pi@IP_OF_RASPBERRY_PI -L 8183:127.0.0.1:8183
Run Node Inspector:
node-inspector --debug-port 8183
Then open Chrome and go to http://127.0.0.1:8080/debug?port=8183
Z-Way Debuggin using Node Inspector
Enjoy!
NB! This is VERY experimental and sometimes v8 (and Z-Way) crashes if you try to inspect Z-Way internal (native) objects in JavaScript (for example, zway.devices and all others). So, do not watch them.
NB! Use old version of node-inspector. Check this: viewtopic.php?f=3419&t=24237&p=66327#p66054
alexey.zimarev
Re: Debugger for Z-Way JavaScript
Post by alexey.zimarev » 27 May 2014 13:48
This is a big thing! So tired of console.log...
It is also very exciting to see signs of Node in Z-Way :)
Post by PoltoS » 27 May 2014 15:22
There are no signs of Node in Z-Way at all. We just use same v8 as NodeJS uses.
But NodeJS have a visual debugger. You can instead use v8 internal debuggin tool.
billyboy
Post by billyboy » 11 Jun 2014 10:03
should port 8183 not be port 8083?
If not then Node Inspector is running but I don't see any files, if not then Node Inspector crashes with a error 500: Servewr Error, SyntaxtError: Unexpected token E.
Post by PoltoS » 11 Jun 2014 11:29
Should be exactly 8183!
billyboy
Post by billyboy » 18 Jun 2014 09:32
I tried everything but node inspector start, the webpage loads but I don't see a script file or running code.
If I press Ctrl+O it opens a window but this is empty?
Post by PoltoS » 18 Jun 2014 12:33
have you started Z-Way with V8_DEBUG=yes on the SAME machine or with ssh tunneling?
billyboy
Post by billyboy » 19 Jun 2014 15:10
Yes, i added V8_DEBUG=yes to /etc/init.d/z-way-server.
I installed Node Inspector on the Raspberry.
And started it: node-inspector --debug-port 8183 (via telnet)
billyboy
Post by billyboy » 19 Jun 2014 15:25
It works now!
I updated to 1.7.1 and node inspector works now.
Just finding out how to use it.
Post by PoltoS » 20 Jun 2014 00:44
Nice! Do you have some howto for installation of node-inspector on RPi? We use it through ssh tunnel, but may be you can share with others this?
