Hi all!
I'm using Z-wave server 1.7.2 and have 5 pcs of the switch TKB Home TZ68G which you also can control manually with a button on the device. However, even though the store and the manufacturer tells me it will report its status back to the controller (and so does on their HC2, Vera, Vera lite etc), I can not get it to report back to my Razberry/Z-wave server. I´ve read about groups, associations etc. but have not been able to find out if it is possible to configure this right now on my setup.
The same issue goes for my Duwi ip44 switch...
What can be done ?
Getting status updates from TKB Home TZ68G
Re: Getting status updates from TKB Home TZ68G
Manuals from TKB Home website contain a lot of fancy pictures and nearly zero technical details.
According to the manual from http://manuals.zwaveeurope.com, TZ68G doesn't support associations. But it is dated back 2012, so they might update the firmware since then.
Duwi IP44 (according to the same website) is kinda a dinosaur. It doesn't support associations, and it is based on SDK 5.02, which is now totally outdated.
But again, the information might be outdated, as I can't find any recent manuals.
You can also watch a log file while switching device on and off. Probably it actually sends its status in some weird way, but z-way just can't understand it is a status update.
Ok, when I bought the T68ZG it specified associations. A couple of questions.
> How can I upgrade these units, if there exists an update of course...(I have tried to communicate with TKBHOME, not yet received a good answer to my questions)
> Where do I go in z-wave server to find the log ?
> Is this possible to solve on a Razberry according to you, the fact that people using HC2 etc. tell me that these units do send their status (at least confirmed that the TKBHOME switch does).
Dunno. Most likely, you cannot do it yourself, even if there was an update. Currently most of devices available on the market can be firmware updated only by sending them back to manufacturer.grelle wrote:How can I upgrade these units, if there exists an update of course...(I have tried to communicate with TKBHOME, not yet received a good answer to my questions)
The log is in /var/log/z-way-server.log. You might use tail command to get updates in real-time:grelle wrote:Where do I go in z-wave server to find the log ?
tail -f /var/log/z-way-server.log
If it really works on HC2, it is likely possible on RaZberry too. Let's just hope those people are not talking about Z-Wave.me Plug-In Switch (russian modification of TKB TZ68-G which looks exactly the same as original device, but has custom firmware inside), which really supports associations very well.grelle wrote:Is this possible to solve on a Razberry according to you, the fact that people using HC2 etc. tell me that these units do send their status (at least confirmed that the TKBHOME switch does).
This is what I get when I power the switch of manually:The log is in /var/log/z-way-server.log. You might use tail command to get updates in real-time:
[2014-08-20 20:58:35.710] RECEIVED: ( 01 0E 00 49 84 0A 08 04 10 01 25 27 70 86 72 AD )
[2014-08-20 20:58:35.711] SENT ACK
[2014-08-20 20:58:35.712] Node info received: 10
[2014-08-20 20:58:35.714] SETDATA devices.10.data.basicType = 4 (0x00000004)
[2014-08-20 20:58:35.715] SETDATA devices.10.data.genericType = 16 (0x00000010)
[2014-08-20 20:58:35.716] SETDATA devices.10.data.specificType = 1 (0x00000001)
[2014-08-20 20:58:35.721] SETDATA devices.10.data.deviceTypeString = "Binary Power Switch"
[2014-08-20 20:58:35.723] SETDATA devices.10.data.nodeInfoFrame = byte[5]
( 25 27 70 86 72 )
[2014-08-20 20:58:35.724] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-08-20 21:00:48.533] RECEIVED: ( 01 0E 00 49 84 0A 08 04 10 01 25 27 70 86 72 AD )
[2014-08-20 21:00:48.534] SENT ACK
[2014-08-20 21:00:48.536] Node info received: 10
[2014-08-20 21:00:48.537] SETDATA devices.10.data.basicType = 4 (0x00000004)
[2014-08-20 21:00:48.538] SETDATA devices.10.data.genericType = 16 (0x00000010)
[2014-08-20 21:00:48.540] SETDATA devices.10.data.specificType = 1 (0x00000001)
[2014-08-20 21:00:48.545] SETDATA devices.10.data.deviceTypeString = "Binary Power Switch"
[2014-08-20 21:00:48.546] SETDATA devices.10.data.nodeInfoFrame = byte[5]
( 25 27 70 86 72 )
[2014-08-20 21:00:48.547] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
And yes, even the manufacturer TKBHOME tells me via email that it indeed should report it's status and they tell me that is likely my controller that is not configured the right way.
Your device is sending NIF instead of a status report (BASIC_REPORT / SWITCH_BINARY_REPORT). It is not really speicification-compliant, but you can do a workaround at least:
This will request device status each time it sends its NIF.
var dev = zway.devices[10];
dev.data.nodeInfoFrame.bind(function(type) {
if (type == 0x41 /* Updated | PhantomUpdate */) {
dev.SwitchBinary.Get();
Alright, now we are getting somewhere Where Do I put the code ?
Can this NIF sending behavior be changed you think ?
For testing, put it in the end of automation/main.js. Maybe you'll want to write a module for that later (because main.js will be overwritten in case you update z-way-server version), but that will do for now.
Don't forget to restart z-way-server after that.
I doubt that behavior can be changed. You better ask TKB
Nice work pofs! Your script works. Where Do you live so I can buy you a beer
But how in .. are HC2, Vera, Vera light and so on able to receive the status ? Are they programmed like your script ?
Vera certainly contains a lot of hacks and workarounds for different devices. Probably the same for HC2.
On the other hand, we decided not to make hacks in Z-Way, encouraging users to use certified and up-to-date devices. But workarounds can still be made on JS level.
