This module turns off devices after a defined time of inactivity. Activity can be measured using multiple binary sensors/devices, like movement sensors, door sensors or switches. Also allows to specify a delay for auto off checks after the device was initially turned on.
Tested with Z-Way version v2.2.2
Bug/Issue tracker at https://github.com/maros/Zway-AutoOffInactive/issues
Documentation at https://github.com/maros/Zway-AutoOffIn ... /README.md
Download at https://github.com/maros/Zway-AutoOffInactive/releases
Installation can be done directly via git or via the the Zway App-Store. Install the BaseModule first.
[userModule] Automated Inactivity Switch Off (Up 2016/10/19)
Z-Way 2.2.4 on Raspi B | My Zway GitHub repos | Amazon Wishlist to support module development
Re: [userModule] Automated Inactivity Switch Off
Hi maros,
I get the following error when I create an App with this module:
BTW. There is a typo in the installation instruction on GitHub.
it refers to WindowControl instead of AutoOffInactive.
regards
masque
2016-01-04 21:21:00.236] [I] [core] Notification: error (core): Cannot instantiate module: AutoOffInactive: TypeError: Cannot read property 'call' of undefined
[2016-01-04 21:21:00.247] [I] [core] TypeError: Cannot read property 'call' of undefined
at new AutoOffInactive (automation/userModules/AutoOffInactive/index.js:14:27)
at AutomationController.instantiateModule (automation/classes/AutomationController.js:287:24)
at AutomationController.createInstance (automation/classes/AutomationController.js:504:14)
at ZAutomationAPIWebRequest._.extend.createInstance (automation/ZAutomationAPIProvider.js:656:40)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:258:41)
at automation/WebserverRequestRouter.js:32:35
at WebServer.document_root (automation/Webserver.js:27:11)
git clone https://github.com/maros/Zway-WindowControl.git WindowControl --branch latest
masque
hi, the dependency declaration was missing in module.json. This was fixed on the master branch
It's working now. thanks.
Would it make sense to include Multi level switches for sensor as well ?
A logical rule could be used to define if the Multilevel switch has been inactive or not.
An example for usage would be: Turn of the washing maschine and send a notification if the powerlevel of the washing maschine as been 3W for more then 10 minutes.
Or am I wrong and such scenarios are solved with existing modules already ?
regards
masque
regards
masque
Hi, you can already use binary switches as input sensors. Unfortunately your use-case is not covered by this module, and I don't think that it is covered by any other module out of the box. However I believe that it could be solved by combining this module with a virtual binary sensor that is triggered whenever the power level of the washing machine is < 3W and untriggered if > 3W (triggering could be done via custom js code or my ConditionSwitch module)
I did a test with the "if then" module allready. Unfortunately it's not enougth to trigger between <3W and >3W as the maschine is reaching that condition during normal work as well. Therefore I was looking for something that includes a timer. This would give the possibility to only switch off the maschine when the power level is held for a certain time.
I thought about using your Automated Incativity Switch Off module for this, but it does use binray switches as sensor only. I'm not really a developer, but I thought about giving it a try to localy "customize" your module and try to include multi level switches. The bad point on this is, that I would spend a lot of time to end in a dead track, as all the changes you apply to the "normal" module would not go into my customized one.
But I guess you do not plan to include multi level switches to your module. right ?
Actually the Inactivity Switch does not have a timer on its own. It simply runs periodically and checks the level and last update time of all sensors. If the sensors are off and if the last update is longer ago than the configured timeout then the device is switched off. Adding multilevel switches/sensors would be kind of hard here - since the last change timestamp changes frequently (eg. if the power meter changes from 3.2 -> 3.1W)
maybe try this solution
1. Create a virtual binary switch
2. Use my ConditionSwitch module to turn off the virtual switch whenever power level of the controlled device is >3w (and turn it on if <3w)
3. Use the Auto Inactivity Off module with the binary switch as sensor input
ok, that's a cool idea.
I will try this as soon as I've figured out why the Conditional Switch module gives me the following error when I create an app.
As the error does not come from the module it has to be something else.
This time permissions are ok, so I will have to check what else could casue this.
[2016-01-06 23:23:07.673] [I] [core] Notification: error (core): Cannot instantiate module: ConditionSwitch: TypeError: undefined is not a function
[2016-01-06 23:23:07.698] [I] [core] TypeError: undefined is not a function
ok, we're getting closer. After restarting everything I now get the following error:
shouldn't it be dayofweekNow instead of dayNow ?
[2016-01-06 23:39:09.775] [E] [core] Callback execution error: ReferenceError: dayNow is not defined
at automation/userModules/ConditionSwitch/index.js:139:46
at Function._.each._.forEach (automation/lib/underscore.js:146:17)
at ConditionSwitch.checkCondition (automation/userModules/ConditionSwitch/index.js:123:11)
at ConditionSwitch.initCallback (automation/userModules/ConditionSwitch/index.js:66:10)
I've changed line 139 in index.js to dayofweekNow and got the ConditionSwitch Module working.
Additionally I've added the binary switch to the module.json of AutoOffInactive module as the Binary switches have not been shown in the drop down list.
after this I have been able to configure everything.
Unfortunately it is not working.
The ConditionSwitch seems to be OK, but AutoOff is not triggering.
I guess it's not just to add the binary switches.
"sensors" : {
"fields" : {
"item" : {
"datasource" : "namespaces",
"field" : "optionLabels",
"optionLabels" : "namespaces:devices_sensorBinary:deviceName,namespaces:devices_switchBinary:deviceName",
"type" : "select"
"sensors" : {
"items" : {
"enum" : "namespaces:devices_sensorBinary:deviceId,namespaces:devices_switchBinary:deviceId",
"field" : "enum",
"required" : true
