Static PC Controller Configuration
marco
Post by marco » 18 Apr 2016 09:09
Hi All, is there any one that can explain why, in the interview page of the zway configuration section (expert UI), choosing razberry as device id 1, I can not complete interview and I always read "Device seems to be dead"?
According to log file, after a Foce Interview call, I have
SETDATA devices.1.instances.0.commandClasses.152.data.interviewDone = False
[2016-04-18 06:03:58.527] [D] [zway] SETDATA devices.1.instances.0.commandClasses.152.data.interviewCounter = 9 (0x00000009)
[2016-04-18 06:03:58.528] [zway] Node 1:0 CC Security Interview started
[2016-04-18 06:03:58.528] [zway] Node 1:0 CC Security: sending Scheme Get
[2016-04-18 06:03:58.528] [E] [zway] Dropping packet to myself (node 1)
[2016-04-18 06:03:58.528] [E] [zway] Error returned from (command->cc->interview_handler)(zway, command): Not implemented by the library (-3)
Is this normal?
Marco
Screen Shot
Marco
kandalf
Re: Static PC Controller Configuration
Post by kandalf » 22 Jun 2016 09:04
Hi there,
since yesterday i would setup my raspberry new and install a fresh sd card, now i have the same problem.
Have you more information about the problem?
Raspberry PI with Z-Wave.me Board
2 x Fibaro Double Relay-Switch FGS 222
2 x Fibaro Shutter FGR 222
Fibaro Multi Sensor
Z-Wave.me RemoteControl
marco
Post by marco » 22 Jun 2016 09:48
Hi Kandalf,
I'm sorry, no news from my side
Marco
kandalf
Post by kandalf » 22 Jun 2016 10:39
It was a mistake, that only comes when you have no device included. It is a view problem.
When you look at controller information you can see that all is ok.
So include one device and then in the configuration list you can see the new device and all is fine.
Fibaro Multi Sensor
marco
Post by marco » 22 Jun 2016 11:12
For me it was not properly like this. At the moment I'have no more this reporting status (it disappeard on a previous upgrading) but in the past it was appearing even if I had 15-20 devices included. Probably there is a relation with the software release but I don't know the causes.
Marco
Post by PoltoS » 31 Jul 2016 01:25
Are you trying to interview #1 from #1 ? it will not reach itself through radio ;)
In fact the #1 selection in Configuration tab gices you no info. You don't need it. In latest Z-Way we have even decided to hide it not to frustrate users.
marco
Post by marco » 31 Jul 2016 09:23
thanks,
Marco
Marco
