AeoTec Smart Dimmer Gen 2
Guffer
Post by Guffer » 12 Aug 2016 13:33
Good morning, I hope someone can point me in the right direction here.
I am in the process of setting up my network and I have succesfully added several Fibaro fdg 212s and a nodon octan remote. I am having trouble with adding some AeoTec dimmers. They are Gen 2 and the only one I can find in the device description list is the gen 6 which as different config classes it seems. I have had a brief look in to modifying the ZDDX to locally 'add' the device but I am a little bit stuck. Can anyone point me to a link where I can learn more about ZDDX and how to create my own?
Thanks in advance!
Guffer
Re: AeoTec Smart Dimmer Gen 2
Post by Guffer » 17 Mar 2017 17:26
No one?
Post by PoltoS » 18 Mar 2017 23:58
You can use Exper Commands tab in Expert UI and do everything according to Aeotec manual
Guffer
Post by Guffer » 22 Apr 2017 11:03
Hello PoltoS, thanks for replying.
I can use the ExpertUI to control basic functions but I cannot find a device description that allows me to use it fully. I can set it to version 6 but the interview doesn't work. An older version Razwave had the version 2 description which worked well. I guess I am going to have to install that on another device and try and copy the XML over in to the latest version.
silverhack
Post by silverhack » 23 Apr 2017 05:44
I usually don't use the device descriptions for almost any of my devices. Is there something in particular that you are not able to do with the device?
