z-way 2.2.4 issues
Popp Wod
z-way 2.2.4 issues
Post by Popp Wod » 24 Oct 2016 23:32
I just upgraded my Popp hub v1 to the new version. It worked fine so far.
At least one thing announced in the project read me is not available:
- time zone setting on first access page
What concerns me most is, there is no firmware update menu entry available any longer on management menu.
best regards,
Wod
Re: z-way 2.2.4 issues
Post by PoltoS » 25 Oct 2016 10:59
You will be notified about new fw at login page.
You can change TZ in Mainainance menu.
Popp Wod
Post by Popp Wod » 25 Oct 2016 11:50
Thanks for your answer. I am quite new to z-way so sorry for any silly questions.
Unfortunately I do not see any maintenance menu? :oops:
Furthermore i noticed the following thing:
I have 4 IP-cams included and managed to see the cam streams. Once a stream is broken, e.g. cam is not accessible, the UI crashes.
However, I noticed some good things as well:
- local weather app is working now
- PAN08 now works better and blinds can be set to e.g. 40% with the blinds-popup menu
Popp Wod
Post by Popp Wod » 26 Jan 2017 12:45
Now 2.2.5 is out fixing the initial problem.
But how to update to the new version when the menu entry is missing?
Post by PoltoS » 26 Jan 2017 13:41
On Popp Hub updates are done in a different way. We will release an update soon and you will notice it during login.
Popp Wod
Post by Popp Wod » 20 Feb 2017 21:45
Now 2.3 is out and still no update option in 2.2.4
I somehow doubt there will be an update option once a new version is released. How should this work...
And what the heck is different with a PoppHub compared to a Raspberry v2 running a Razberry extension beside the logo exchange?
Is there a manual way to update by copying files to SD-Card directly?
Post by PoltoS » 27 Feb 2017 22:50
Hm.. It should be present, since the file is on the server. I'll ask out team to check it.
http://razberry.z-wave.me/z-way-server/ ... v2.3.0.tgz
