Can't update Firmware
Re: Can't update Firmware
Tried the same. But after upgrade to 2.2.5 i get alway the message "Could not retrieve data from remote serve" (http://IP:8083/expert/#/uzb)
@diemue
Did you run the bootloader and firmware update while in 2.1.2 before upgrading to 2.2.5?
I did a factory reset of the z-wave controller before all this. Be aware that this can fail. I have several Z-wave controllers and this i currently not my production unit so i could afford a failure.
Small followup on this topic.
After update to 5.16 i got instability issues in domoticz that uses openzwave. Previously it was fairly stable. Reverted back to 5.04 but for some reason it still does not work reliably in domoticz. With Z-way it is working fine.¨
All tests on raspberry pi 2 using Z-way image updated to 2.2.5 or latest release of domoticz on raspian jessie lite.
This is what my system says before I try to upgrade.Torulf wrote:Do anyone know what was implemented between 5.06 and 5.16?
http://razberry.zwave.me/index.php?id=32
In another discussion I have suggested to first contact support@z-wave.me for advice!
They never publish what is in experimental features.
Wondering why the bootloader is different.
- zwave 504.JPG (21.32 KiB) Viewed 13035 times
I have no idea, except for the fact that I am running v2.3.0-rc1 and I had updated to firmware 5.06 a month ago or so.
Try update to v2.3.0-rc1 and se if you can downgrade from there. Tried some later build (rc2 or rc3) but newer got it stable then. I am using openhabian on my test device at the moment and dont remember all.
https://service.z-wave.me/expertui/uzb/ ... _05_06.bin
But make sure to remove first 0x1800 bytes (6144) which are zero before writing it to 0x7800 address
Copy paste "v2.3.0-rc1" without ""pepeEL wrote:But how downgrade to v2.3.0-rc1 ?
In update i must write "v2.3.0-rc1" ?
Oops... you killed all your network data. Hope you had a backup!pepeEL wrote:I clear all memory in chip.
As mentioned, we have never performed that. No step-by-step instructions. No one have ever tried such a geeky way. We have Z-Wave programmers to do it.pepeEL wrote:But tell me step by step how i must write it to my chip. If i done succed i write a manual on forum.
- Locate on the programming 6 pins: Vcc, MOSI, MISO, SCK, RST, GND. You need all but RST
- Pull EEPROM CS (you have to locate it) to LOW to select the EEPROM on SPI.
- Set up some Arduino or professional programmer (it MUST be 3V!!!!) to read//write into M25PE20 EEPROMS
- Write at 0x7800 the .bin file above (full file byte per byte skipping 0x1800 = 6144 bytes)
- Then write 1 at 0x77ff
- Release CS
- Pull RST to LOW and the release (to reboot Z-Wave chip)
- It should update then and boot on 5.04 (it is the latest)
