v2.3.0 is out!
Re: v2.3.0 is out!
Post by PoltoS » 27 Feb 2017 22:52
Raspberry version will not work. AFAIK we have provided WD Team with our 2.3.0 builds - they need time to evaluate them
vlad
Re: v2.3.0 is out!
Post by vlad » 04 Mar 2017 04:47
going from 2.2.5 to 2.3.0 Niffler module does not work any more, so problems with locks and GE switches.
I don't know what was changed in binding methods but looks like next code (Niffler js) is not running correctly on 2.3.0:
Niffler.prototype.niffle = function(virtualDevice) {
var index = this.getDeviceIndex(virtualDevice.id);
if ( global.ZWave && !isNaN(index) ) {
var binderMethod;
var deviceType = virtualDevice.get('deviceType');
if(deviceType === 'doorlock'){
binderMethod = function(type) {
console.log("Niffler","doorlock alarm event");
zway.devices[index].DoorLock.Get(); //This call will poll lock info
zway.devices[index].Alarm.data.V1event.bind(binderMethod);
}else{
zway.devices[index].Basic.Get();
zway.devices[index].data.nodeInfoFrame.bind(binderMethod);
this.binderMethods.push( [index,binderMethod] );//Add method to array for later unbind
Niffler module get initialized and subscribed to device events (can see log messages) but something wrong with actual event handling where NIF package from device should trigger DoorLock.Get() or Basic.Get() for locks or GE switches...
RolfKunkel
Re: v2.3.0 is out!
Post by RolfKunkel » 19 Mar 2017 18:19
I upgraded my Popp hub controller to v2.3.0 without changing anything else in the configuration. Now all of the sudden I do not see anymore status changes of my danalock. The lock is working fine means I can open and close it but the changes are not visible in the Events Log and the status change is as well not visible in device view and room view. In Expert Mode view the device change is visible.
I did not check if other devices are as well impacted but I think so because the list of devices in Event Log is quite short.
Rolf
Looks like a bug in new release. Do you have a work around to overcome this issue. I
VladM
Re: v2.3.0 is out!
Post by VladM » 27 Mar 2017 12:19
Issues with association in z-way-server-Windows-v2.3.0-2-g0767a2a.msi
in expert/#/configuration/association/4 i can't add/edit association for device. it just desepiare from screen after few seconds waiting.
There is no such problem In z-way-server-Windows-v2.2.4.msi
uwevoigt
Re: v2.3.0 is out!
Post by uwevoigt » 27 Mar 2017 23:26
I've got a Popp Hub v2. The moment I open Management, I get a pop up stating: Unable to load license key from remote server. In firmware update I than only see that the current version is v2.2.4-rc20, no option to update. How do I get 2.3.0 on my Hub?
Re: v2.3.0 is out!
Post by PoltoS » 28 Mar 2017 01:33
RolfKunkel wrote:I upgraded my Popp hub controller to v2.3.0 without changing anything else in the configuration. Now all of the sudden I do not see anymore status changes of my danalock. The lock is working fine means I can open and close it but the changes are not visible in the Events Log and the status change is as well not visible in device view and room view. In Expert Mode view the device change is visible.
Rolf
I confirm, this was fixed in v2.3.1 (released today - you will be able to upgrade soon)
VladM
Re: v2.3.0 is out!
Post by VladM » 28 Mar 2017 15:13
PoltoS wrote: I confirm, this was fixed in v2.3.1 (released today - you will be able to upgrade soon)
z-way-server-Windows-v2.3.1-3-g80d91ec.msi upgrate/new install got error at log in:
SmartHome UI - ERROR
Unable to update data
silverhack
Re: v2.3.0 is out!
Post by silverhack » 29 Mar 2017 02:04
I have updated the firmware (Smarthome UI -> Settings -> Management -> Firmware Update) and when I go to Info, it shows Firmware version 2.3.1 but UI version is only 1.5.0 and in the Expert UI -> Network -> Controller Info, it shows UI version 1.1.0
Is there something I'm missing in the update process?
aivs
Re: v2.3.0 is out!
Post by aivs » 29 Mar 2017 14:27
Try to refresh page with resetting cache, in chrome CTRL+SHIFT+R
silverhack
Re: v2.3.0 is out!
Post by silverhack » 29 Mar 2017 21:33
Yep, that worked. Sorry, I should have known better. I tried Ctrl+Shift+R previously, but I just recently switch from Windows to Mac and have to get used to doing Cmd+Shift+R instead :)
