Multiples Channels
Chiquitoloco
Multiples Channels
Post by Chiquitoloco »
i'm still playing with zuno and it's pretty cool!!!!
I've setted up multiples sketch
- 2 switchs
- 1 DHT 22
- 1 Motion sensor
- 1 Lux
- 1 door sensor
All work very well separately.
So for the fun i've try to put all these sketchs in one.
After include in the Fibaro HC2, i 've some troubles :
- The motion sensor appears like switch and the value is return to the root devices (see attachment file)
- I've 2 Lux sensor
- 3 weirds sensors these with the red dot
- the door sensor doesn't appears.
There is the configuration of my report channels
Switch 1 : zunoSendReport(1);
Switch 2 : zunoSendReport(2);
Lux : zunoSendReport(3);
Motion : zunoSendReport(4);
Temperature : zunoSendReport(5);
Humidity : zunoSendReport(6);
Door : zunoSendReport(7);
here a part of the sketch
//Routing Slave Node
//Setup 7 Channels (up to 10 Channels)
ZUNO_SETUP_CHANNELS(ZUNO_SWITCH_BINARY(getterSwitch01, setterSwitch01),
                    ZUNO_SWITCH_BINARY(getterSwitch02, setterSwitch02),
                    ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_LUMINANCE, SENSOR_MULTILEVEL_SCALE_LUX, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS, getterLuminance),
                    ZUNO_SENSOR_BINARY_MOTION(getterMotion),
                    ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_ONE_DECIMAL, getterTemperature),
                    ZUNO_SENSOR_MULTILEVEL_HUMIDITY(getterHumidity),
                    ZUNO_SENSOR_BINARY_GENERAL_PURPOSE(getterReedInput));
//Setup SceneId & Associations Group
ZUNO_SETUP_ASSOCIATIONS(ZUNO_ASSOCIATION_GROUP_SCENE_CONTROL);
// Getters and setters
void setterSwitch01(byte value) {
    digitalWrite(relay01, (value > 0) ? HIGH : LOW);
    zunoSendReport(1);
byte getterSwitch01(){
  switchValue01 = digitalRead(relay01);
  return switchValue01;
void setterSwitch02(byte value) {
    digitalWrite(relay02, (value > 0) ? HIGH : LOW);
    zunoSendReport(2);
byte getterSwitch02(){
  switchValue02 = digitalRead(relay02);
  return switchValue02;
word getterLuminance() {
  Serial.println("Zwave value Lux sent");
  return lastLuxValue;
byte getterMotion() {
  Serial.println("Zwave value Motion sent");
  return lastMotionValue;
word getterTemperature() {
  Serial.println("Zwave value Temperature sent");
  return temperature * 10; //*10 beacause Zwave channel for size 2 and precision 1, value 366 represents 36.6 see : https://z-uno.z-wave.me/Reference/ZUNO_SENSOR_MULTILEVEL/
byte getterHumidity() {
  Serial.println("Zwave value Humidity sent");
  return humidity;
byte getterReedInput() {
  Serial.println("Zwave value Reed Input sent");
  return reedValueToSend;
if you have some ideas...
thx
ftrueck
Re: Multiples Channels
Post by ftrueck »
Chiquitoloco
Thanx ftrueck, but i still don't understand what you did.
Did you put all your report on the channel 1, like that :
zunoSendReport(1);
Because i think i tried and it didn't work.
This is not very clear for me, i follow the official 10 sensor sketch from zuno and they put each sensor with a different channel.
Can you publish in your post your final sketch to get an example??
Let me know.
Thx
