[userModule] Synology Surveillance Station (SSS) Web API sw
fez
Post by fez » 08 Feb 2017 02:53
This module will enable you to control the Synology Surveillance Station through its Web API. It creates a virtual binary switch. Based on the provided credentials it will log in, send the given on/off command with the session ID and log off. This could be used to start and stop recording, switch on and off SSS notifications, etc. for complete command set please check the Synology Surveillance Station Web API manual. The format is left open to offer greater flexibility. Try the commands in a browser before using them here. Synology changed the web API so not all commands specified in its manual will work.
Here are some examples for SSS commands:
- start recording on camera (cameraId=1)
/webapi/_______________________________________________________entry.cgi?api=SYNO.SurveillanceStation.ExternalRecording&method=Record&version=2&cameraId=1&action=start
- stop recording on camera (cameraId=1)
/webapi/_______________________________________________________entry.cgi?api=SYNO.SurveillanceStation.ExternalRecording&method=Record&version=2&cameraId=1&action=stop
- enable SSS email motion detection notifications
/webapi/entry.cgi?5=1&api=SYNO.SurveillanceStation.Notification.Filter&version=1&method=Set&eventGroupType=2&eventType=5&filter=1
- disable SSS email motion detection notifications
/webapi/entry.cgi?5=0&api=SYNO.SurveillanceStation.Notification.Filter&version=1&method=Set&eventGroupType=2&eventType=5&filter=1
toket: teamit_beta
igitlin
Re: [userModule] Synology Surveillance Station (SSS) Web API sw
Post by igitlin » 17 Aug 2017 21:44
How to take snapshot, not record video, use this plugin and send snapshot to email
fez
Post by fez » 18 Aug 2017 00:38
That will not be possible with this module.
You could use this module as a start point to handle the login/session key handling and implement the snhapshot feature. The method is documented in the Synology SS manual, section 2.3.4.4
If you do implement it, please post it on the developers portal.
