Issues with HRT4-ZW thermostat
babelmonk
Post by babelmonk »
I've had no end of problems getting the UI to play nicely with this 'stat.
Using the API / an App to change the set temperature works OK - the device updates after the wakeup interval as I'd expect.
However, in the UI, the value goes back and forth endlessly if I try to set it - and it's nearly impossible to get the right number. In addition, there is a set of exceptions in the log for every change.
I've uploaded a GIF animation of what happens, logged errors in the UI and the z-way-server.log file excerpt (below). Any hints would be appreciated.
92340 [2017-02-14 09:43:33.647] [D] [zway] RECEIVED: ( 01 0B 00 04 00 13 05 31 05 05 01 27 F1 )
92341 [2017-02-14 09:43:33.647] [D] [zway] SENT ACK
92342 [2017-02-14 09:43:33.647] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
92343 [2017-02-14 09:43:33.647] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
92344 [2017-02-14 09:43:33.647] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
92345 [2017-02-14 09:43:33.648] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.5.scaleString = "%"
92346 [2017-02-14 09:43:33.648] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.5.val = 39.000000
92347 [2017-02-14 09:43:33.648] [D] [zway] SETDATA devices.19.instances.0.commandClasses.49.data.5 = Empty
92348 [2017-02-14 09:43:35.354] [I] [core] ---  ZWayVDev_zway_44-0-67-1 performCommand processing: {"0":"exact","1":{"level":"2"}}
92349 [2017-02-14 09:43:35.355] [D] [zway] SETDATA devices.44.instances.0.commandClasses.67.data.1.setVal = 2.000000
92350 [2017-02-14 09:43:35.355] [I] [zway] Adding job: ThermostatSetPoint Set
92351 [2017-02-14 09:43:35.356] [I] [zway] Adding job: ThermostatSetPoint Get
92352 [2017-02-14 09:43:35.356] [I] [zway] Node 44:0 CC ThermostatMode: Thermostat Mode 1 is not supported by device (modemask 0x0)
92353 [2017-02-14 09:43:35.361] [I] [core] Notification: error (module): Error during perform command execution: Error: Invalid argument
92354 [2017-02-14 09:43:35.369] [I] [core] Error: Invalid argument
92355     at Error (native)
92356     at t_vDev.(anonymous function).self.controller.devices.create.handler (automation/modules/ZWave/index.js:3356:61)
92357     at _.extend.performCommand (automation/classes/VirtualDevice.js:295:37)
92358     at ZAutomationAPIWebRequest._.extend.performVDevCommandFunc (automation/ZAutomationAPIProvider.js:377:60)
92359     at ZAutomationAPIWebRequest.handlerFunc (automation/ZAutomationAPIProvider.js:3032:52)
92360     at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:259:41)
92361     at automation/WebserverRequestRouter.js:32:35
92362     at WebServer.document_root (automation/Webserver.js:35:11)
92363 [2017-02-14 09:43:35.376] [I] [core] Notification: device-info (device-status): {"dev":"Hallway Thermostat SetPoint","l":"2 °C"}
92364 [2017-02-14 09:43:35.420] [I] [core] [BaseModule-26] Set lastLevel to 2 for ZWayVDev_zway_44-0-67-1 (was 15)
92365 [2017-02-14 09:43:35.620] [I] [core] ---  ZWayVDev_zway_44-0-67-1 performCommand processing: {"0":"exact","1":{"level":"21.5"}}
92366 [2017-02-14 09:43:35.620] [D] [zway] SETDATA devices.44.instances.0.commandClasses.67.data.1.setVal = 21.500000
92367 [2017-02-14 09:43:35.621] [I] [zway] Adding job: ThermostatSetPoint Set
92368 [2017-02-14 09:43:35.621] [D] [zway] Job 0x13 (ThermostatSetPoint Get): removing duplicate
92369 [2017-02-14 09:43:35.621] [I] [zway] Node 44:0 CC ThermostatMode: Thermostat Mode 1 is not supported by device (modemask 0x0)
92370 [2017-02-14 09:43:35.622] [I] [core] Notification: error (module): Error during perform command execution: Error: Invalid argument
92371 [2017-02-14 09:43:35.626] [I] [core] Error: Invalid argument
92372     at Error (native)
92373     at t_vDev.(anonymous function).self.controller.devices.create.handler (automation/modules/ZWave/index.js:3356:61)
92374     at _.extend.performCommand (automation/classes/VirtualDevice.js:295:37)
92375     at ZAutomationAPIWebRequest._.extend.performVDevCommandFunc (automation/ZAutomationAPIProvider.js:377:60)
92376     at ZAutomationAPIWebRequest.handlerFunc (automation/ZAutomationAPIProvider.js:3032:52)
92377     at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:259:41)
92378     at automation/WebserverRequestRouter.js:32:35
92379     at WebServer.document_root (automation/Webserver.js:35:11)
92380 [2017-02-14 09:43:35.629] [I] [core] Notification: device-info (device-status): {"dev":"Hallway Thermostat SetPoint","l":"21.5 °C"}
92381 [2017-02-14 09:43:35.662] [I] [core] [BaseModule-26] Set lastLevel to 21.5 for ZWayVDev_zway_44-0-67-1 (was 2)
92382 [2017-02-14 09:44:02.637] [D] [zway] RECEIVED: ( 01 08 00 04 00 30 02 98 40 19 )
92383 [2017-02-14 09:44:02.637] [D] [zway] SENT ACK
92384 [2017-02-14 09:44:02.637] [D] [zway] SETDATA devices.48.data.lastReceived = 0 (0x00000000)
92385 [2017-02-14 09:44:02.639] [I] [zway] Node 48:0 CC Security: sending Nonce Report
92386 [2017-02-14 09:44:02.639] [I] [zway] Adding job: Nonce Report
92387 [2017-02-14 09:44:02.640] [D] [zway] SENDING (cb 0xcb): ( 01 11 00 13 30 0A 98 80 52 20 EE 3B 9E 9F 69 B7 25 CB 49 )
92388 [2017-02-14 09:44:02.643] [D] [zway] RECEIVED ACK
92389 [2017-02-14 09:44:02.649] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
92390 [2017-02-14 09:44:02.649] [D] [zway] SENT ACK
92391 [2017-02-14 09:44:02.649] [D] [zway] Delivered to Z-Wave stack
Animated issue with UI
zwave thermostat issue.gif (412 KiB) Viewed 5146 times
Errors in UI
Errors in UI
