External antenna
paaland
External antenna
Post by paaland » 07 Aug 2017 14:09
I wan't to remove the built-in and add an external antenna. But I find the instructions unclear.
Normally an antenna has two leads, one for the core and one for ground. According to instructions I can either use point 4: open hole for pig tail, or point 5 for uFL connector. But point 5 has three soildering points.
What is the correct way to add external antenna?
petergebruers
Re: External antenna
Post by petergebruers » 07 Aug 2017 14:14
An ufl socket has three pins, you have to solder the socket to those pins.. Two pads are ground. Use ufl if you already have an antenna with ufl connector crimped on. Ufl looks like a tiny coaxial connector.
Post by PoltoS » 11 Aug 2017 23:48
Or just connect a wire to 4. It should be 86 mm (for 868 MHz) or 82 (for 908/915 used in US).
Don't forget to remove the resistance connecting to the PCBA antenna to disable it
e-rook
Post by e-rook » 19 Oct 2017 00:08
I did this exercise recently with piece of wire and helped with range and responsivity
http://e-rook.org/2017/10/17/razberry2- ... extension/
aus_fas
Post by aus_fas » 17 Oct 2018 04:30
Which part or where should I break the PCB, any pictures please ?
