z-way-server does not start in Stretch
coolbloke1324
Re: z-way-server does not start in Stretch
Post by coolbloke1324 » 20 Mar 2018 15:43
Hey folks,
Not ideal, but you can install libssl1.0.0 on stretch by running:
wget http://ftp.de.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u7_amd64.deb
sudo apt install ./libssl1.0.0_1.0.1t-1+deb8u7_amd64.deb
After this, I was able to run z-way-server on stretch.
Mir88d
Post by Mir88d » 28 Apr 2018 15:09
coolbloke1324 wrote:
20 Mar 2018 15:43
Hey folks,
It doesn't help me at all :
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libssl1.0.0:amd64' instead of './libssl1.0.0_1.0.1t-1+deb8u7_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libssl1.0.0:amd64 : Depends: libc6:amd64 (>= 2.14) but it is not installable
E: Unable to correct problems, you have held broken packages.
And I can't instal Raspbian Jassie because I have Raspberry Pi 3 B+ which is incompatible with old Jessie.
I think the only way for me is returning UZB stick...
Maybe someone knows another z-wave server which is compatible with z-wave.me UZB stick and Raspbian Stretch?
aLiEnHeAd
Post by aLiEnHeAd » 28 Apr 2018 23:09
Mir88d wrote:
28 Apr 2018 15:09
This solution did not work for you?
https://forum.z-wave.me/viewtopic.php?f=3417&t=26138
Mir88d
Post by Mir88d » 11 May 2018 12:47
aLiEnHeAd wrote:
28 Apr 2018 23:09
Mir88d wrote:
28 Apr 2018 15:09
Thank you! It’s solved my problem
epoitras
Post by epoitras » 23 Aug 2018 02:40
It's been a year now this issue is open. It should really be time to fix it and support stretch.
Post by PoltoS » 27 Aug 2018 20:29
Please try this:
VER="2.3.8-rc6" && cd /tmp/ && rm -f *.deb && wget https://storage.z-wave.me/z-way-server/z-way-${VER}_armhf.deb && wget https://storage.z-wave.me/z-way-server/webif-1.1_armhf.deb && wget https://storage.z-wave.me/z-way-server/zbw-1.1_all.deb && sudo dpkg -i *.deb
Answer:
Y on /etc/init.d/z-way-server
Y on /etc/logrotate.d/z-way-server
N on /etc/zbw/userid
N on /etc/zbw/passwd
N on /etc/zbw/local_port
skavan
Post by skavan » 02 Sep 2018 08:49
port 1883 doesn't activate.
presumably because of some failure pre-launch.
I have tried your suggestions above (VER= bla bla bla).
This is quite ridiculous. Stretch has been the default OS for the rpi for ages. I bought the razberry to use with zway...and it is nuts that I have zero functionality.
Please give me a step by step on how to get this working on a Pi 3 with Stretch. The Razberry is attached to dev/ttyS0.
stkar
Post by stkar » 06 Sep 2018 22:13
Hi
Eureka!
Downloaded
2018-06-27
Stretch 4.14
Downloaded
RaZBerry 2.3.7
Thanks for this "mtylerb" you are a God!!!
https://www.raspberrypi.org/forums/view ... p?t=215389
Now with changed to "9".
$ cd \tmp
$ wget http://mirrordirector.raspbian.org/rasp ... _armhf.deb
$ sudo dpkg -x libssl1.0.0_1.0.1t-1+deb8u9_armhf.deb .
$ sudo mv usr/lib/arm-linux-gnueabihf/lib* /opt/z-way-server/libs/
Maybe last sudo mv with some permission change ... do not remember exactly.
Wow, everything works (22 aug)!
