Fibaro RGBW Controller 0-10V Input
Eagle
Post by Eagle » 18 Sep 2017 16:36
is there any way in zway to use the Fibaro RGBW Controller as a 0-10V sensor readout?
I changed parameter 14 to the correct value for 4 channel analog 0-10v sensor inputs (34952). But the zway GUI is only showing me dimmer, color, electric meter etc.
thank you!
Re: Fibaro RGBW Controller 0-10V Input
Post by PoltoS » 26 Sep 2017 02:45
Never tried, but may be you need to Force Interview (Request NIF first) or even re-include it?
Eagle
Post by Eagle » 26 Sep 2017 18:53
I tried, but this also did not work. The only thing i recognized, is that the Color Value for Red and a dimmer level changes, as the Voltage input changes. For now ill take the dimmer level and calculate my real input voltage level!
Im on 2.3.2 Beta for WD PR4100.
Thanks!
petergebruers
Post by petergebruers » 30 Sep 2017 23:01
That is correct... The input is read through the dimmer. This unfortunately means it has only 100 steps, so 0.1 V resolution. It is a pity, because the internal ADC has better resolution, but there is no means to read it...
