Hom is it done?
I try the link with my ip-adress but it doesn´t work. I guess I must type in the sensor number somewhere? But how?
I would like to try bruteforce too, though the interview stucks at 86%
Interview incomplete - Fibaro Universal Sensor FGBS-001
Re: Interview incomplete - Fibaro Universal Sensor FGBS-001
ip:8083/JS/Run/zway.devices"NNN".instances"III".AlarmSensor.data.interviewDone
Hi, yes, you should exchange the IP address in the biginning, with your real Ip address.
NNN must be exhaged with your device ID an the instance you have to try from 1 to 4. This worked for me.
Thanks! I will try tomorrow.
NNN, is it #14 for example? And its just to try I, II, III and IIII?
Yes, NNN is 14 for example, I´m not sure if i try instances with 1 2 3 4 or I II III IV or IIII
But you will see it in the browser.
Also, the link was incomplete, you have to type in at the end = true
ip:8083/JS/Run/zway.devices"NNN".instances"III".AlarmSensor.data.interviewDone = true
Thank´s Now finally it worked for me too
Thats what I thougt too at last. But mine were working in previous versions so it got a little strange. But the link did it for me
I tried the link above (double checked it) but I get "SyntaxError: Unexpected string".
http://192.168.1.200:8083/JS/Run/zway.d ... wDone=true
What am I doing wrong?
http://ip:8083/JS/Run/zway.devices[NNN] ... wDone=true
I think because i changed the [ with " to explain it.
Aha, that was the trick. That worked. The tab "configuration" however doesn't get populated unfortunately. It says "This device doesn't have the necessary service".
Yes, you may configure it with the Expert Commands menu
