Razberry не отвечает, греется.
kimifish
Post by kimifish » 04 May 2018 16:13
Добрый день.
Купил Razberry 2, поставил на RPi 3 model B c Stretch, установил z-way c
и переставил библиотеки скриптом из
support.z-wave.eu/libs
Ну, думаю, теперь должно заработать...
Не заработало:
pi@raspberrypi:~ $ tail -n 30 /var/log/z-way-server.log
[2018-05-04 13:00:31.711] [D] [zway]   [55] "RFPowerLevelGet"
[2018-05-04 13:00:31.711] [D] [zway]   [56] "SendTestFrame"
[2018-05-04 13:00:31.711] [D] [zway]   [57] "SetPromiscuousMode"
[2018-05-04 13:00:31.711] [D] [zway]   [58] "PromiscuousCommandHandler"
[2018-05-04 13:00:31.711] [D] [zway]   [59] "WatchDogStart"
[2018-05-04 13:00:31.711] [D] [zway]   [60] "WatchDogStop"
[2018-05-04 13:00:31.711] [D] [zway]   [61] "ZMEFreqChange"
[2018-05-04 13:00:31.712] [D] [zway]   [62] "ZMERestore"
[2018-05-04 13:00:31.712] [D] [zway]   [63] "ZMEBootloaderFlash"
[2018-05-04 13:00:31.712] [D] [zway]   [64] "ZMECapabilities"
[2018-05-04 13:00:31.712] [D] [zway] Opened device: /dev/ttyAMA0
[2018-05-04 13:00:31.712] [D] [zway] Worker thread successfully created
[2018-05-04 13:00:31.712] [D] [zway] Worker thread entry point
[2018-05-04 13:00:31.712] [I] [zway] Adding job: Get controller info and supported function classes
[2018-05-04 13:00:31.722] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-05-04 13:00:31.924] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-05-04 13:00:31.924] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-05-04 13:00:32.125] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-05-04 13:00:32.125] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-05-04 13:00:32.327] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-05-04 13:00:32.327] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2018-05-04 13:00:32.327] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2018-05-04 13:00:32.327] [C] [zway] Get Serial API Capabilities returned zero.
[2018-05-04 13:00:32.327] [I] [zway] Removing job: Get controller info and supported function classes
[2018-05-04 13:00:32.337] [D] [zway] Worker thread exit point
[2018-05-04 13:00:32.337] [D] [zway] Worker thread successfully finished
[2018-05-04 13:00:32.348] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2018-05-04 13:00:32.367] [I] [core] Error: Bad data - communication failed
[2018-05-04 13:00:32.368] [I] [core] Tried 5 times without success. Stopping tries.
[2018-05-04 13:00:32.371] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
pi@raspberrypi:~ $
Чип на razberry при этом греется страшно, выше сотни. Это же не норм? =)
При нажатии кнопки ребута не происходит вообще ничего, диод не моргает.
Что делать-то? Сдаваться? Ругаться с продавцом на ибее? Менять?
Попробовать всё-таки Jessie?
IgoriokLT
Re: Razberry не отвечает, греется.
Post by IgoriokLT » 05 May 2018 01:06
Попробуйте Jessie, на нем все работает. Работа на Stretch, как я понял, еще сырая.
kimifish
Post by kimifish » 05 May 2018 09:43
IgoriokLT wrote:
05 May 2018 01:06
А греться чип должен настолько? Палец обжигает буквально.
Post by PoltoS » 07 May 2018 03:54
Скорее всего модуль воткнули со сдвигом на одну-две колодки. Возможно, в самом начале случайно. Это привело к его выгоранию. Так греться не должен точно (штатно не более 50°С).
igitlin
Post by igitlin » 15 May 2018 21:45
по этому лучше UZB - все то же самое только шансов воткнуть не так нету, можно использовать с другим софтом, можно использовать не только на малине, а и на виртуалках, н занимает GPIO слоты, ну и собственно используя USB удлинитель можно вынести передатчик дальше от малины или другого компа.
Я вообще не понимаю какие преимущества есть Raxberrу перед UZB
IgoriokLT
Post by IgoriokLT » 16 May 2018 20:46
Не надо отдельно покупать лицензию, она уже зашита в модуль. GPIO продублированны на самой плате расширения.
igitlin
Post by igitlin » 17 May 2018 10:43
Так и UZB продаются с лицензией и без на выбор. Зато возможности использования шире. Так часть портов GPIO сама разберри и использует так что под свои нужны меньше останется, ещё из за этой платы нет возможности экран на малину поставить. В общем плюсов не вижу
