HC-SR04 and DS18B20 help?
KristjanV
Re: HC-SR04 and DS18B20 help?
Post by KristjanV » 11 Jul 2018 10:00
Thanks man! But... now for some reason ultrasonic reading is a bit off. In code i have deviation 10cm and tank height 110cm so every 10cm in real life shoulb be 10% in the reading. But it isn't. If i move an object 10cm the reading drops only 4%. I have input voltage for Z-Uno on 5.02V, so that should not be an issue.
KristjanV
Post by KristjanV » 12 Jul 2018 08:38
Other than that, the project turned out quite well.
I have put Z-Uno and Vera Edge into one box. The whole idea was to make a device that can measure different temperatures and also pellet bunker fulfillment level and you can access that information through mobile phone plus get notifications when temperatures are too high/low and also when bunker level gets too low. To justify the use of z-wave devices, it leaves open the opportunity to always add more devices like smoke detector or flood sensor etc.
Heres some pictures for you guys.
Post by PoltoS » 15 Jul 2018 01:00
Can we share your project with a reference to you on our site?
KristjanV
Post by KristjanV » 16 Jul 2018 08:03
PoltoS wrote:
15 Jul 2018 01:00
Yes ofcourse, no problem!
KristjanV
Post by KristjanV » 20 Jul 2018 11:12
Here's the code i used. Doesn't look too good but it works (for me). Feel free to adjust and fix =)
And BIG THANKS to you all who helped me get this thing working!
-PoltoS
-mdietinger@gmail.com
-p0lyg0n1
// 4 temperature sensors DS18B20, 1 ultrasonic distance sensor HC-SR04
#include "ZUNO_DS18B20.h"
#define DS18B20_BUS_PIN 11                  // Pin to which DS18B20 bus is connected
#define N_SENSOR 4                          // Number of DS18B20 sensors
// You need to adopt ZUNO_SETUP_CHANNELS and add more getters if tou need more sensors
OneWire ow(DS18B20_BUS_PIN);
DS18B20Sensor ds18b20(&ow);
#define ADDR_SIZE 8                         // Size of address of devices on 1-wire bus
byte addresses[ADDR_SIZE * N_SENSOR];        // Here we store all the scanned addresses
#define ADDR(i) (&addresses[i * ADDR_SIZE]) // Macro to simplify our life
byte number_of_sensors;                     // Number of sensors found
word temperature[N_SENSOR];                 // Here we store temperatures
//ultrasonic sensor
int readPin = 9;
int triggerPin = 10;
byte controlState = 0;
byte percentage;
//ultrasonic sensor
// Define Z-Wave channels. Add more if you need more sensors
ZUNO_SETUP_CHANNELS(
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp1),
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp2),
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp3),
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp4),
//ultrasonic sensor
        ZUNO_SENSOR_MULTILEVEL_GENERAL_PURPOSE(getter)
void setup() {
  number_of_sensors = ds18b20.findAllSensors(addresses);
//ultrasonic sensor
  Serial.begin();
  pinMode(readPin, INPUT);
  pinMode(triggerPin, OUTPUT);
  digitalWrite(triggerPin, LOW);
//ultrasonic sensor
void loop() {
  for (byte i = 0; i < number_of_sensors; i++) {
    // Read temperature
   // It already encoded for format VVV.vv and doesn't use float
    temperature[i] = ds18b20.getTempC100(ADDR(i));
//ultrasonic sensor
      byte distance, heightTank, deviation;
      int duration;
      // WE HAVE TO DO IT JUST ONCE, NOT INSIDE  DS18B20 LOOP^
      //You'll probably want to change the next 2 lines.
      // The first one is the max. level of the water.
      // The next one is how high the sensor is above that max. level.
      heightTank=110;
      deviation=10;
      delayMicroseconds(10);
      digitalWrite(triggerPin, HIGH);
     // this code loads the uC hard, so lets report all values after it ends
      duration = pulseIn(readPin, HIGH, 100000);
      // This uses float thats not good for this uS, it eats lots of code
      // distance = (duration/2)/29.1;
      // percentage = (byte)(100-(((distance-deviation)*100)/heightTank));
     // alternative will be: (RISC style)
      duration >>= 1; // /2
      duration *= 100;
      duration /= 291;
      duration -= deviation;
      // To ensure there is no overflow
      duration = max(duration, heightTank);
      duration *= 100;
      duration /= heightTank;
      percentage = 100 - duration;
      Serial.println(percentage);
     // Report all the sensors at the end of the loop
     for(byte i=0;i<5;i++){
       zunoSendReport(i+1);
     // delay while the OS could do something with  reports & radio
     delay(3000);
// Getters. Add more if you need more sensors
word getterTemp1() {
  return temperature[0];
word getterTemp2() {
  return temperature[1];
word getterTemp3() {
  return temperature[2];
word getterTemp4() {
  return temperature[3];
//ultrasonic sensor
byte getter() {
  return percentage;
//ultrasonic sensor
