Fibaro temperature error
apica
Post by apica » 07 Jun 2018 14:22
I've just received an invalid temperature value from the Fibaro motion sensor (FGMS-001). Image attached.
I have searched google and seems that the sensor is reporting the value correctly. Any clue of where the error come from?
Thank you
Temperatura fibaro error.png (10.4 KiB) Viewed 2625 times
apica
Re: Fibaro temperature error
Post by apica » 07 Jun 2018 19:27
Updated again with a wrong value. Any suggestion?
Thank you
Temperatura fibaro error 2.png (5.21 KiB) Viewed 2619 times
IgoriokLT
Post by IgoriokLT » 12 Jun 2018 23:57
Maybe temperature offset?
apica
Post by apica » 13 Jun 2018 10:25
Thank you for the reply. They all have default values.
Is there any interesting log that I can share to help debugging?
IgoriokLT
Post by IgoriokLT » 16 Jun 2018 01:29
Did you try to re-include device?
apica
Post by apica » 18 Jun 2018 10:34
IgoriokLT wrote:
16 Jun 2018 01:29
No, but the temperature value was good the day before. Re-including may solve the problem, but it might occur again.
IgoriokLT
Post by IgoriokLT » 18 Jun 2018 22:53
Can you please check Parameter 66 value in Expert Menu?
apica
Post by apica » 19 Jun 2018 10:07
Thank you IgoriokLT,
I checked and it has the value 64536 (minimum value). I don't understand this value as I never changed it.
