Compile problem
sitevnic
Compile problem
Post by sitevnic » 25 Jun 2018 16:47
Hi
Recently I've get strange error: ZUNO_BMP180_sdcpp_.cpp:730:3:error:use of undeclared identifier 'Wire'
I've used that sketch before, but suddenly it stops working. I've reinstall Arduino IDE and still the same...
I'm using copy of "OLED and BMP180" sketch, see below:
#include "Wire.h"
#include "ZUNO_BMP180.h"
#include "ZUNO_OLED_I2C.h"
ZUNO_BMP180 bmp;
OLED oled;
void setup() {
bmp.begin();
oled.begin();
oled.clrscr();
void loop() {
delay(1000);
oled.gotoXY(0,0);
oled.print("Millis:");
oled.print(millis());
oled.gotoXY(0,1);
oled.print("Temperature ");
oled.print(bmp.readTemperature());
oled.println(" *C");
oled.print("Pressure ");
oled.print(bmp.readPressure()/133.32);
oled.println(" mm");
delay(2000);
Re: Compile problem
Post by PoltoS » 25 Jun 2018 19:55
Which version of Z-Uno package?
p0lyg0n1
Re: Compile problem
Post by p0lyg0n1 » 25 Jun 2018 20:16
It's a problem of the first beta. Please remove all from packages/Z-Uno & staging/packages and reload board from test-ucxx repository.
sitevnic
Re: Compile problem
Post by sitevnic » 01 Jul 2018 12:47
I had Z-Wave>Me package 2.1.3.
sitevnic
Re: Compile problem
Post by sitevnic » 01 Jul 2018 14:03
Hi
I'm confused with:
remove packages/Z-uno - it is enough to uninstall that package from board manager, or I need to do something more?
remove staging/packkages - where to find it?
I've uninstall Z-Uno by Z-WAVE>ME package from Boards Manager, changed repository to test-ucxx and install again Z-Uno package. But this didn't help. How to remove all packages?
p0lyg0n1
Re: Compile problem
Post by p0lyg0n1 » 01 Jul 2018 15:18
I tested this code once more with current version (2.14) it compiles ok.
You have to remove these folders first (it's from Z-Uno troubleshooting page):
http://z-uno.z-wave.me/getting-started/ ... allPackage
After reinstalling packages please check that you select a right one board in menu :)
sitevnic
Re: Compile problem
Post by sitevnic » 10 Jul 2018 12:20
Hi
Finally I managed to fix it according to http://z-uno.z-wave.me/getting-started/ ... allPackage help.
However I had to find all packages not in roaming folder, but inside documents folder.
