Any idea and suggestion is welcomed.
Is there a library for ZUNO to control a stepper motor?
jeffhumster
Hello everyone, I am trying to control a step motor using ZUNO, I have seen arduino use the <stepper> library to control motor, I wonder does ZUNO has a similar library?
Re: Is there a library for ZUNO to control a stepper motor?
I have looked here https://github.com/arduino-libraries/St ... tepper.cpp.
The code is simple. There are no specific hardware features. The only thing that we have to modify is passing of parameters especially for constructors. In case of Z-Uno the stack usage is critical. Don't use large list of parameters, use pointers instead.
original code:
Optimized code for Z-Uno (note I use byte instead of int)
You could try it yourself.
original code:
Stepper::Stepper(int number_of_steps, int motor_pin_1, int motor_pin_2,
int motor_pin_3, int motor_pin_4,
int motor_pin_5)
Stepper::Stepper(byte number_of_steps, byte * motor_pins)
jeffhumster
Thanks, I will try the solution, and will let u know how things going. Really appreciate your help.
today we have released a new beta 2.1.5b1 that contains library for step motors. The news will be further in separate topic. The library calls ZUNO_Stepper. Here is an example that shows how to use it. We don't have any step motor in the office. I have debugged it using logic analyzer. So, it'll very cool if you could test it with your hardware.
#include <ZUNO_Stepper.h>
CCBYTE motor_pins[] = {0,1,2,3,4}; // z-uno pins connected to motor, 4-pins mode
Stepper stepper_motor(64, sizeof(motor_pins), motor_pins); // 64 steps for whole rotate
void setup() {
stepper_motor.setSpeed(1000); // 1000 rpms
void loop() {
stepper_motor.step(10); // 10 steps forward
delay(1000);
stepper_motor.step(-5); // 5 steps backward
delay(1000);
