Can't update apps
rafale77
Can't update apps
Post by rafale77 » 27 Jul 2018 04:14
I see this in the log when I try to update an app in the smart home UI
And I get an error that it cannot download the update. I can however delete apps. I was suspecting that I had some folder permission issues.
[2018-07-26 18:08:11.333] [core] Installing app MailNotifier ...
[2018-07-26 18:08:11.334] [E] [HTTP] Callback execution error: ReferenceError: installer is not defined
at AutomationController.installModule (automation/classes/AutomationController.js:652:3)
at ZAutomationAPIWebRequest._.extend.updateModule (automation/ZAutomationAPIProvider.js:929:29)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:259:35)
rafale77
Re: Can't update apps
Post by rafale77 » 27 Jul 2018 19:56
Actually I am seeing more errors in different areas and have tried on a brand new installation too. I am suspecting that my installation of ubuntu either has some missing folders don't have the right folder permission. Could anyone tell me what folders zway downloads to?
Post by PoltoS » 27 Jul 2018 21:01
Looks you are using some of the beta v2.3.8. Please confirm
rafale77
Post by rafale77 » 27 Jul 2018 23:28
I am using 3.0.0 RC15. I just installed and tested 2.3.6 release after moving my config files to it and have the same problem so I doubt it is a problem with the zway itself. It is more likely due to some settings with my ubuntu install. I did not have these errors when I was on 3.0.0 RC12.
Post by PoltoS » 28 Jul 2018 01:21
It should be with libraries. Start the s/w in shell and look in the stderr
rafale77
Post by rafale77 » 28 Jul 2018 03:06
PoltoS wrote:
28 Jul 2018 01:21
aha... found something:
Failed to load module modskininstaller.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modskininstaller.so)
Module modcrypto.so loaded
Module modenocean.so loaded
Module modzbw.so loaded
Failed to load module modnotification2ext.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modnotification2ext.so)
Module moddhs.so loaded
Module modws.so loaded
Failed to load module modiconinstaller.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modiconinstaller.so)
Module modhomekit.so loaded
Failed to load module modhttp.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modhttp.so)
Module modzwave.so loaded
Module modsockets.so loaded
Failed to load module modinstaller.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modinstaller.so)
I checked my libraries and I do have libcurl.so.4. It is because libcurl4 is now compiled with OPENSSL_4 which standard on Ubuntu 18.04 LTS. Can you please update the modules so they can accept both 3 and 4?
BeckySpencer
Post by BeckySpencer » 30 Jul 2018 15:37
First Of All you should to reset your mobile and after then try update App if this is not work again then your software problem check it your mobile repair men! Well owerful “Text Blast notification services api” to protects all your applications and in-app activities and keep you safe and secure!
spotifywebplayer
Contact:
Post by spotifywebplayer » 31 Jul 2018 09:59
I having same problem.
