strings.h strncmp returs always a zero
ondrej_bajer
Post by ondrej_bajer » 10 Aug 2018 21:46
Hi guys,
I want to use strncmp function in order to compare start of two chararrays. But it returns me zero in every case. What am I doing wrong, please?
Test sketch here:
void setup() {
   Serial.begin (9600);
#include <string.h>
char CharBuffer[50] = "123456789ABC";
char CompareBuffer[50] = "123456789XXX";
word NumberOfToCompare;
int Result;
void loop () {
  NumberOfToCompare = 5;
  Result = strncmp (CharBuffer, CompareBuffer, NumberOfToCompare);
  Serial.println(Result);
  NumberOfToCompare = 11;
  NumberOfToCompare = 12;
  delay(1000);
ondrej_bajer
Re: strings.h strncmp returs always a zero
Post by ondrej_bajer » 24 Aug 2018 20:04
Hi guys,
just wanted to share my findings. To be honest, I found a solution after couple of hours but I was too lazy to post it here immediatelly. Shame on me.
So, the string.h library is okay, the problem is with the declaration. CharArray declared as char CharBuffer[50] = "123456789ABC" does not work correctly. However if I put chars into an array later, and then add a termination zero, it worsk like a charm.
Hope this will help somebody else.
Message to the Z-Uno development team: Thanks a lot for bringing string.h lib, it helped me a lot!
Regs,
ONDREJ
Post by PoltoS » 24 Aug 2018 23:08
Thanks, we will check what's wrong with this definition.
bastibart
Post by bastibart » 16 Dec 2018 10:48
Hi guys
Array initialization with string literals is still not working.
char buf[] = "hello world"; // won't fill buf[]
FIRMWARE DATA
REVISION:02.14
Z-WAVE FREQUENCY:EU
ORIGINAL FW. CRC32: 45 54 B1 BC
MAXIMUM CODE SIZE: 30 KB
CURRENT FW. CRC16: FE A1
RADIO CHANNELS: 02
