SerialAPI: Command: 0xa4 is not supported by this SerialAPI
newuser
Post by newuser » 05 Sep 2018 09:56
Hello!
I'm using Z-Wave.Me UZB as a bridge controller for Z/IP Gateway. It works fine until I start to communicate with devices. Every time when I send commands I get the next errors in zipgateway.log.
 SerialAPI: Command: 0xa5 is not supported by this SerialAPI
 SerialAPI: Assertion failed at /var/lib/jenkins/jobs/Full_S2_Gateway_release/workspace/src/serialapi/Serialapi.c:600
 SerialAPI: SendFrameWithResponse() returning failure
33324 virtual_nodeid_init_count: 0
33341 Creating virtual node
33341 create failed, will retry
34341 Creating virtual node
34341 create failed, will retry
I tried to find out the problem in the source code of Z/IP Gateway and did not find the answer.
This problem is also described on Z-Wave Public Forum.
Thank you
newuser
Re: SerialAPI: Command: 0xa4 is not supported by this SerialAPI
Post by newuser » 05 Sep 2018 13:20
I discussed this problem with developers of Z/IP Gateway. They claim that the problem related to outdated version of Z-Wave SerialAPI. And it seems to be true. In my log I can see:
Version: Z-Wave 4.61, type 7
Also they mentioned that the actual version on today is 6.01:
Version: Z-Wave 6.01, type 7
And finally I was told that (I'm quoting here):
The Z-Wave.Me UZB runs modified serial API.
Could you help me? What should I do? Maybe I missed something?
P.s. Previously I updated the firmware of my UZB stick as advised here.
zipgateway.log.zip
(3.23 KiB) Downloaded 25 times
Post by PoltoS » 07 Sep 2018 00:56
As I remember, 0xa4 is related to bridge firmware functions. Are you sure you picked up the bridge version of the firmware after upgrading? You can check it on Controller Info page. There should be a lot of 0xa_ functions marked as present but not supported by Z-Way (we do t use them).
As for Serial API version, don't look in it. We increment it slowly, while SiLabs is incremeting it faster. In fact we base our firmwares on latest 6.0x
newuser
Post by newuser » 11 Sep 2018 09:46
Hello! Thank you for you reply.
There is a way to update the firmware without Z-Way for example by using command line? Like I can change the frequency using a shell script (changezwf.sh).
I ask about it because I'm not sure that Z-Way updates my UZB correctly. I tried to update the firmware several times but 'Controller Info' and 'Firmware Update' pages do not change their state (I expect that after update Serial API Version will be 05.27).
Post by PoltoS » 12 Sep 2018 09:06
You need the last option in the picture
newuser
Post by newuser » 12 Sep 2018 09:13
Do you mean this one?
Post by PoltoS » 12 Sep 2018 09:59
No, last one. You want bridge, right?
newuser
Post by newuser » 12 Sep 2018 11:37
Yes, I want the bridge version. Regarding that you offer I did it several times and I've just done it again to be sure. Nothing changed: the firmware version is the same as before update (on 'Controller Info' page), the list of updates is the same too (on 'Firmware Update' page). And Z/IP Gateway still does not work (the same errors in log). P.s. What do green/gray icons with arrows inside them mean on 'Firmware Update' page?
Does Z-Way have an app log? Maybe it will give me a clue.
Post by PoltoS » 14 Sep 2018 11:34
sure, the log is in /var/log/z-way-server.log
newuser
Post by newuser » 17 Sep 2018 15:03
As I described before I updated my firmware several times. The last time I did it I saved Z-Way log file (see attachments) in the hope to find something in it. This log captures the time from Z-Way daemon startup time to the moment when Z-Way said that the firmware had been updated. As I can see there are no errors in it except JavaScript exceptions. Also 'Controller Info' page says that I have 'Bridge Controller', SDK v6.71.01, Serial API v05.25 (see the image above). So I can conclude that I have the latest version of the firmware. And with this version I have the problem with Z/IP Gateway. So that I think that this firmware does not support some part of Z/IP.
Could you provide a list of the commands which are implemented in your firmware?
z-way-server.zip
(335.43 KiB) Downloaded 23 times
