Reporting bugs
Reporting bugs
Post by PoltoS » 29 Sep 2018 10:09
When reporting bugs please make sure to provide us minimal information about the issue you are facing. You can post issues here on the forum in a separate thread for each bug or on github
Here is the template for your bug report:
Please fill your bug report here
More info:
  • Z-Uno bootloader version:2.1.x (release version or test-ucxx?)
  • Security:none/S2/S0
  • Frequency:EU/US/RU/ANZ-BR/IN/CN/JP/KR/TW
  • Device included:yes/no
  • Device included securely by controller:yes/no
  • Controller:RaZberry/Z-Way/Fibaro HC2/Fibaro HCL/Vera/other
Connected peripherals:
Please add here a description, photo and/or schematics of your peripherals
Code:
If you can minimize your code to still reproduce the bug, please do it before reporting
your code here
Compiler log:
Please paster the compiler output
                     FIRMWARE DATA
        REVISION:02.15
        Z-WAVE FREQUENCY:RU
... (more lines up to)
        CHIP:1546 REVISION:4
Debug output:
Connect to UART0, enable Logging->UART0, open logging monitor and dump the output. Should look like:
0000:00 00
0010:A0 00
0011:A0 00
0012:A0 00
