2.3.8. - Binding Problem - No Devices
Popp Wod
Re: 2.3.8. - Binding Problem - No Devices
Post by Popp Wod » 01 Nov 2018 08:20
PoltoS wrote:
28 Oct 2018 12:31
Will ping today to check where it landed
Any update, Polto?
Is this related to the Linux version we are using? Or is this related to the image?
I never had any RC images installed. Just one additional Tool installed, called monit.
Why is there no answer of your support-team?
BR, Wod.
michap
Post by michap » 01 Nov 2018 12:46
PoltoS found just now a solution for fixing.
I have tested and it is working fine:
Login into Shell, then execute:
cd /opt/z-way-server
rm libs/libarchive.so*
sudo apt-get install libarchive12
ln -s /usr/lib/arm-linux-gnueabihf/libarchive.so libs/libarchive.so.13
Restart the Popp Gateway, and all will be back.
Michael
temp
Post by temp » 02 Nov 2018 09:42
Can anyone confirm this?
kovi44
Post by kovi44 » 03 Nov 2018 14:44
Dear all,
I'm running 2.3.7 on RPI3 - raspbian jassie. I did upgrade to 2.3.8 yesterday with no success. After the upgrade and reboot the z-way-server do not start at all. I try to start it manually but it stops with some errors. Then I just restore the backup of 2.3.7 (which is done automatically - just rename the previous one) and the 2.3.7 start again without any problem.
Do someone else got the same issue using the same distro and hw? Thanks
michap
Post by michap » 03 Nov 2018 20:22
kovi44 wrote:
03 Nov 2018 14:44
This maybe another problem - please open a new topic, if other issue.
The current issue happen at "old" POPP Gateway (or any Pi with Wheezy) after updating to 2.3.8 - that no devices visible and a binding error will be shown.
The published fix is ONLY for this case.
Recommendation is to upgrade the OS for older systems - if possible.
Michael
optimizer
Post by optimizer » 04 Nov 2018 20:19
michap wrote:
01 Nov 2018 12:46
Michael
Thanks.
I can confirm that this fixed my controller issues (same as thread starter) after updating the RaZberry firmware to 2.3.8 from 2.3.6 (raspbian - wheezy).
/Tobbe
Popp Wod
Post by Popp Wod » 05 Nov 2018 12:09
Version 2.3.8 has been retracted for Popp hub v.1 and is actually no longer available.
temp
Post by temp » 06 Nov 2018 18:38
optimizer wrote:
04 Nov 2018 20:19
michap wrote:
01 Nov 2018 12:46
Michael
Thanks.
/Tobbe
You are using the razberry Board 2 Extension fit Raspberry???
optimizer
Post by optimizer » 07 Nov 2018 00:28
temp wrote:
06 Nov 2018 18:38
optimizer wrote:
04 Nov 2018 20:19
Thanks.
/Tobbe
I'm using Razpberry board v1 plugged onto a Raspberry B GPIO. My z-wave controller hardware is from January 2014. Not sure I dare to update any more times now. Last time I updated, a year ago?, the webinterface and API was modified slightly and gave me some headache because I had to update all my control scripts (perl).
/T
ronie
Post by ronie » 07 Nov 2018 18:23
Hey guys,
please excuse the long absent ...
@michap thx for your time to investigate this issue and providing this fix as workaround.
As you already found out the problem is related to teh old Debian 7 (Jessie) on which your last Z-Way v2.3.7 was running.
I've prepared some receipes that will hopefully help to solve this issue:
Upgrade Raspbian Wheezy (Debian 7) to Jessie (Debian 8) to support Z-Way v2.3.8 (specially for Popp Hub 1)
Revert a Z-Way upgrade with help of the terminal
