Problem updating bootloader
sil
Post by sil » 18 Dec 2018 22:46
I got this message:
Openning port ..............................
Openning port .............................. OK
Stoping the user code ..............................
And you can wait, wait, wait, nothing happened.
What to do ?
sil
Re: Problem updating bootloader
Post by sil » 18 Dec 2018 23:06
I got the previous message with a MAC computer.
With a PC:
Stoping the user code .............................. OK
Closing port ..............................
Closing port .............................. OK
Error 0 returned 1 for ACK
Error 1 Unknown exception:list index out of range
If I try to download a sketch
C:\Users\home\AppData\Local\Temp\arduino_build_794263/SimpleBlink.ino
--- USING a list of libraries from:
C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.4\libraries
C:\Users\home\Documents\Arduino\libraries
*** Collecting prototypes...
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: SimpleBlink.cpp with SDCPP...
Compiling SimpleBlink_sdcpp_.cpp ...
Compiling SimpleBlink_sdcpp_.cpp ...Compiling file "LLCore_arduino.c" by means of SDCC...
sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "LLCore_arduino.c"
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051.exe -plosgffw "LLCore_arduino.rel" "LLCore_arduino".asm
Compiling file "Print_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "Print_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Print_ucxx.rel" "Print_ucxx".asm
Compiling file "Stream_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "Stream_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Stream_ucxx.rel" "Stream_ucxx".asm
Compiling file "HardwareSerial_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "HardwareSerial_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HardwareSerial_ucxx.rel" "HardwareSerial_ucxx".asm
Compiling file "HLCore_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "HLCore_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HLCore_ucxx.rel" "HLCore_ucxx".asm
Compiling file "SimpleBlink_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "SimpleBlink_ucxx.c"
sdcc: sdas8051.exe -plosgffw "SimpleBlink_ucxx.rel" "SimpleBlink_ucxx".asm
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\home\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "main.c"
sdcc: sdas8051.exe -plosgffw "main.rel" "main".asm
sdcc: Calling linker...
sdcc: sdld.exe -nf "main.lk"
Making firmware file: C:\Users\home\AppData\Local\Temp\arduino_build_794263/SimpleBlink.ino-0214.hex ...packihx: read 38 lines, wrote 56: OK.
Fixing ISR table in C:\Users\home\AppData\Local\Temp\arduino_build_794263/SimpleBlink.ino-0214.hex ...Making binary firmware file C:\Users\home\AppData\Local\Temp\arduino_build_794263/SimpleBlink.ino-0214.bin. Using in Z-Way for wireless update procedure.[Done]
Elapsed:7.32999992371 s
Sketch uses 710 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 155 bytes of dynamic memory.
Cleaning user NVM [> ] (0%)
(<class '__main__.ProgrammerError'>, 'compiler.py', 480)
Error 1 Unknown exception "Can't clean NVM data! at=40000"
rrozema
Post by rrozema » 20 Dec 2018 06:58
You could try connecting using a better quality usb cable. I have some (cheap) usb cables that produce similar results. If I use one of my better quality cable, it works fine.
sil
Post by sil » 21 Dec 2018 13:36
solved with rescue mode
