Razberry controller does not recognize Z-Uno FLIRS device
rishamee
Post by rishamee » 06 Jan 2019 11:34
Hi all,
I have a problem when I add a Z-Uno FLIRS-device to my Razberry ZWay controller.
It did work in the past, but now after inclusion in de ZWay-expert-UI the device is shown as Mains, Routing Multilevel Sensor.
I think the problem started after the upgrade to 2.3.8
Some techncal details:
Z-Uno bootloader version: 2.1.3, AND 2.1.4 (both the same behaviour, unless that with 2.1.4 the device is not listed under Device/Battery)
Security: none
Frequency: EU
Device included: yes
Z-Uno config parms (1, 11, 12): all default
Interview result classes (all OK):
Basic, SensorMultilevel, AssociationGroupInformation, DeviceResetLocally, ZWavePlusInfo, MultiChannel, Configuration, ManufacturerSpecific, PowerLevel, FirmwareUpdate, Battery, Association, Version, MultiChannelAssociation, SensorMultilevel, SensorMultilevel
Controller info:
Hardware: RaZberry by Z-Wave.Me
Firmware: SDK Version: 6.71.01, Serial API Version: 05.23
Software Version number: v2.3.8
Code snippet:
#define TEMPSENSORCHANNEL 2
#define SUNSENSORCHANNEL 1
ZUNO_SETUP_CHANNELS(
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE,
                          SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE,
                          SENSOR_MULTILEVEL_SIZE_TWO_BYTES,
                          SENSOR_MULTILEVEL_PRECISION_ONE_DECIMAL,
                          sunGetter),
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
                          SENSOR_MULTILEVEL_SCALE_CELSIUS,
                          tempGetter));
ZUNO_SETUP_CFGPARAMETER_HANDLER(config_changed);
void setup() {
  delay(200);
void loop() {
  zunoSendReport(SUNSENSORCHANNEL);
  zunoSendReport(TEMPSENSORCHANNEL);
  zunoSetBeamCountWU(240);
  zunoSendDeviceToSleep();
int sunGetter() {
  return 123;
int tempGetter() {
   return 200;
void config_changed(byte param, unsigned long* value) {
The Z-Uno works as FLIRS-device, it sends reports every 240 (zunoSetBeamCountWU) seconds. But is does not accept commands from the controller, unless I bring it in rescue-mode.
Does somebodyhave an idea what is going wrong?
(I have the same problem adding sleeping (battery) devices!!)
K.R.
rishamee
Re: Razberry controller does not recognize Z-Uno FLIRS device
Post by PoltoS » 09 Jan 2019 09:30
What do you mean by not accepting commands?
rishamee
Post by rishamee » 11 Jan 2019 16:11
It does not react when I request te battery-status from the expert-UI, for instance. Neither it reacts when I request te actual value of a confuguration parameter or try to set one. Either it does not act like a FLIRS device, or the controller sends the wrong command.
Post by PoltoS » 18 Jan 2019 01:29
Can you check the queue? Are packets sent to Z-Uno or just hanging in the queue? Make sure to exclude and include back after changing the type of device
