UZB1 No Firmware Updates shown in Network -> Controller Info
mcmxb
Post by mcmxb » 17 Mar 2019 04:32
I got a problem with updating my UZB1 Stick to the latest Firmware.
My UZB1 is shown as Static Controller with
SDK Version: 6.51.09
Serial API Version: 05.07
Now i want to update Firmware but when i click "Firmware Update" Button, there are no Updates available.
It says "Your stick uses the latest firmware".
Im on v3.0.0-rc23, same problem accured on another Pi with 2.3.8 running on it.
Can somebody help me getting my UZB1 up to date?!
Re: UZB1 No Firmware Updates shown in Network -> Controller Info
Post by PoltoS » 18 Mar 2019 09:19
The newer fw was disabled recently. We will re-enable it back soon
mcmxb
Post by mcmxb » 18 Mar 2019 14:20
How long do i have to wait?
I guess, i need the Update in order to pair the new Fibaro Roller Shutter v3 (FGR-223).
Or is this a wrong assumption?
petergebruers
Post by petergebruers » 03 Apr 2019 20:57
Running Z-Way 2.3.8 on an oragangepi trying to update UZB1 I get this:
"2017-07-07 5.25 Update bootloader for 5.25 to 40196"
Then when I click Upgrade:
"Unable to update data. /ZWave.zway/ZMEBootloaderUpgrade"
Is this a symptom of what @poltos said: "The newer fw was disabled recently. We will re-enable it back soon", or is it something else?
Post by PoltoS » 06 Apr 2019 17:35
@mcmxb: no, the UZB firmware is not related to the support of the roller shutter
petergebruers: no, should work if shows up in the UI
petergebruers
Post by petergebruers » 07 Apr 2019 04:03
@PoltoS Thanks. I have replaced the O/S running on my orangepizero, which was based on ubuntu xenial, by this newer version: "Armbian_5.75_Orangepizero_Debian_stretch_next_4.19.20". Then reinstalled Z-Way... And then I was able to update the bootloader of my UZB1, good!
So now it has "05.26" with new bootloader, and Firmware update displays "Your stick uses the latest firmware", so I guess that is to be expected and now I have to wait for you to publish "05.32" again?
hunnypuppy
Post by hunnypuppy » 30 Jul 2019 23:24
I had a similar experience and the issue was using Ubuntu 18.10 since it shipped with CURL4 where as z-way-server requires CURL3 to do a firmware update. Solution was to use Ubuntu 16.04
roquej
Post by roquej » 07 Dec 2019 19:26
Currently on 5.07 and want to upgrade to the latest firmware. However, z-wave tells me the UZB1 is at the latest version. Is this due to the raspberry version or that the firmware upgrades were pulled?
Thanks,
JP
