FGRM 222 Rollershutter
donquixote0906
Post by donquixote0906 » 20 Aug 2019 00:45
i have several Fibaro RollerShutter FGRM 222 in my Zwave Network an all devices have the
device description 'Roller Shutter FGRM-222' exept one of them. I was not able to
manually assign this device description in Z-Wave Expert UI, cause there are only
devices with 'Fibaro' at the beginning. The interviews seems to be the same and are successfull.
With other device descriptions FGRM-221 or FGRM-223 it is not possible to handle a correct
callibration.
Does anyone know a solution for this behaviour?
Volker
Re: FGRM 222 Rollershutter
Post by PoltoS » 20 Aug 2019 00:54
Basically you don't even need this file except for easier configuration of parameters. But this is optional - you can set them in the raw UI. Does this work?
Sure it is same version of the firmware (app version)?
donquixote0906
Post by donquixote0906 » 22 Aug 2019 22:42
In my opinion all parameters are the same.
But isnt it possible to select a device descriptor without the Fibaro filter?
And how could i edit the raw UI? (sorry, i am Not very expierienced)
