New iOS and Android apps for Z-Way
Re: New iOS and Android apps for Z-Way
Go in list of hubs and clear cache (swipe the profiler name and choose the middle button)
thanks, that worked
Any idea why i cant access remotely?
Can you do it from browser? Via find.Z-Wave.me
The Android app is a complete desaster. Does not work at all. All that's mentionned does not help. For me the same issue. The app is struck in the loading mode and restarts loading sveral times until it I see the Ooops...and the the same again. What the f... ...
The Popp-app has the same issue in the meantime. Only the old Z-Way app is still working.
Via browser everything works fine, local or via ddns.
I can only agree. It works when you scan the code, but after a couple of hours it doesn't work anymore. It is stuck in the login screen. The problem seems to be be wifi connections. It works if you use mobile data.
I am using a mobile phone with Android 8 and a tablet with Android 7.
We are working on fixing few apparent problems. We plan to release it early November. Hope this will help.
Any news on the release? It's practically unusable for me right now, I cannot login anymore using the (Android) app.
RaZberry ZW0500 1024/2 SDK: 6.82.01 API: 05.39
Z-Way version v4.1.0
We have a debug version to test. We need one more week to make test it in all details. Can send you the apk meanwhile if you wish
Hopefully this is an easy mobile app enhancement request... For multilevel switches, can you please support an "Off" button on the user interface? Currently, there is a "Full" button (and the ability to adjust the level), but there is no easy/fast way to set the level to 0. Both the smarthome and expert web UIs support "On", "Off" and adjusting the level - it is only the mobile app (I'm using an Android device) that lacks "Off".
Noted, we planned to do so.
