v2.3.6 is out!
ronie
v2.3.6 is out!
Post by ronie »
Dear Z-Way/RaZberry users, we are proud to announce a new release: v2.3.6! (released since 04.10.17)
In v2.3.6 we were again focused on some stability issues which appeared in version v2.3.5.
Next to fixes and some usability changes in the UI's, new features are:
Expert UI:
  • The Node route map (Network > Route map) gives you the posibility to visualize connectivity between nodes and also their status, neighbours, associations, reroute rate, hops etc. Upload your own floor plan (max 500 KB) and drag the nodes to their real position of your Smart Home
SHUI:
  • A new enhancement allows you to add PUSH messages (app Mobile App Support v1.1.6+) and E-Mail notifications (app E-mail ME v1.1.6+ ) for apps If-Then (v2.4.4+) and Logical Rules (v1.4.0 +)
  • The restore functionality has been enhanced to allow the controller to be overwritten. This allows you to fully restore your z-way network within SHUI (aditional restore in EUI shouldn't be necessary anymore).
  • Local Apps: Possibility to filter by Updated apps.
  • Online Apps UI-rework
  • RSS news: Added buttons READ MORE and READ.
  • Improvements of the mobile view.
As usually, we keep full backward compatibiliy with previous releases, so you are safe to update.
Full change log (also available here: http://razberry.z-wave.me/z-way-server/ChangeLog)
We'll also try to release this update for all outstanding plattforms as soon as possible :)
We hope you'll enjoy v2.3.6 and we're excited to your feedback.
Big thank's for your support!
Best regards your
Z-Wave.Me Team
PS:
If somebody of you want's to learn more about how to built home automation modules or about our design features skins and icons, please checkout this link below:
https://developer.z-wave.me/?uri=help
https://developer.z-wave.me offers you also the possibility to upload your home automation apps and to share them with all other users.
micky1500
Re: v2.3.6 is out!
Post by micky1500 »
Job Queue not displaying.
Since before v2.3.6-rc3 and still a problem with 2.3.6 final.
In Expert UI, Job Queue. It's random if I get to see any jobs.
I'd say 1 in 20 tries I get to see 20+ jobs in the queue.
Other times I just see Queue length: 0 and the page headers. there will be 20+ jobs there.
Using Chrome, or Edge. and I have cleared the Cache's.
Letting you know so we can make it better !
Raspi 4(Buster), Zwave Version 3.0.6 x It's not my fault... I am not z-way team, just a user of a great system.
micky1500
Re: v2.3.6 is out!
Post by micky1500 »
How does the new Route Map feature work ?
All I see is my uploaded picture, there is no data added.
What am I missing ?
The Node route map (Network > Route map) gives you the possibility to visualize connectivity between nodes and also their status, neighbours, associations, reroute rate, hops etc. Upload your own floor plan (max 500 KB) and drag the nodes to their real position of your Smart Home.
v2.3.6 final
raspberry pi 3, last Jessie build.
Serial API Version: 05.23
Peter
Re: v2.3.6 is out!
Post by Peter »
After update of v2.3.1 to 2.3.6 using web interface z-way crashed (PI 2+ Jessie, uptime >30d on 2.3.1). After several attempts to connect the web interface with no success "refused connection". Moreover it one of my zwave nodes lost its instances (fibaro multisensor - PIR/TAMPER). Back to 2.3.1. needed re-inclusion of fibaro.
Today I’ll try CLI update, anyway issued are expected.
ronie
Re: v2.3.6 is out!
Post by ronie »
Hi @ all,
micky1500 wrote:
09 Oct 2017 16:45
The indication in the headline shows you only the total count of active/busy jobs that have not the state W = Wait wakeup, S = Wait security or D = Done. So that's ok if it says 0 in headline also if there are 20 W jobs in the queue.
micky1500 wrote:
09 Oct 2017 16:54
What am I missing ?
v2.3.6 final
Hmm seems, we can also randomly reproduce this ... on our side we've found this error in browsers console log:
angular.js:9509 Error: missing: 208
    at vu (d3.v4.min.js:3)
    at r (d3.v4.min.js:7)
    at Function.Gg.e.initialize (d3.v4.min.js:7)
    at i (d3.v4.min.js:7)
    at Object.force (d3.v4.min.js:7)
    at e.initNodes (ZWaveRouteMapDraw.min.js:10)
    at new e (ZWaveRouteMapDraw.min.js:2)
    at routemap.js:68
    at C (angular.js:11046)
    at angular.js:11132
So it seems to be a problem of the lib ...
PaketLog looks ok
@PoltoS:
can you please investigate it?
I can send you my PacketLog via Mail - seems to be too big for the upload ;)
@micky1500:
please compare your errors with ours and maybe attach the output of your PaketLog (http://YOUR_RASP:8083/ZWave.zway/PacketLog)
Peter wrote:
10 Oct 2017 09:37
That sounds strange ... can you check how many backups you already have on your RPi under /opt/ ? Maybe it hasn't enough space to add the new z-way-server package
ronie
Re: v2.3.6 is out!
Post by ronie »
klaasjoerg wrote:
09 Oct 2017 21:27
Habe das Update soeben durchgeführt, musste aber leider direkt wieder auf 2.3.5 down graden.
Hintergrund: Die hue-app initialisiert sich nach dem Neustart nicht mehr korrekt und es fehlen ca. 50% der hue-devices bei mir.
(siehe auch error log auszug)...
2017-10-09 18:22:57.186] [I] [core] Creating device switchMultilevel Hue_00:17:88:01:01:22:1b:86-0b_lights_9_hue
[2017-10-09 18:22:57.645] [E] [core] Callback execution error: TypeError: Cannot read property 'indexOf' of undefined
    at automation/classes/AutomationController.js:112:49
    at Function.<anonymous> (automation/lib/underscore.js:620:13)
    at Function._.find._.detect (automation/lib/underscore.js:214:15)
    at null.<anonymous> (automation/classes/AutomationController.js:110:30)
    at EventEmitter.emit (automation/lib/eventemitter2.js:314:33)
    at automation/classes/VirtualDevice.js:251:22
    at Array.forEach (native)
    at _.extend.set (automation/classes/VirtualDevice.js:249:12)
    at Hue.createHueMultilevelDevice (automation/userModules/Hue/index.js:291:7)
    at Hue.createDevices (automation/userModules/Hue/index.js:178:11)
[2017-10-09 18:22:57.659] [I] [core] Hue Finished Auth:
klaasjoerg has reported a bug in the german thread that effects creating vDevs - in his case with HUE app.
I f you have similar problems please try the following in v2.3.6:
Go to each of your rooms, click on edit - you don't need to change anything - and then save the room again.
Try to restart the HUE app or Z-Way Network afterwards.
We will of course take care of the mistake in the meantime :)
micky1500
Re: v2.3.6 is out!
Post by micky1500 »
My Error log for the Route Map feature
I can't attach the files, so pasting the details.
Chrome Console Log error I get :-
angular-cookies.js:6 Error: missing: 50
at vu (angular-cookies.js:6)
at r (angular-cookies.js:6)
at Function.Gg.e.initialize (angular-cookies.js:6)
at i (angular-cookies.js:6)
at Object.force (angular-cookies.js:6)
at e.initNodes (angular-cookies.js:6)
at new e (angular-cookies.js:6)
at angular-cookies.js:6
at C (angular-cookies.js:6)
PacketLog Last entries while trying to view Route Map in browser :-
[{"updateTime":1507628687,"delivered":false,"deliveryTime":130,"packetLength":15,"nodeId":23,"returnRSSI":[127],"hops":[],"returnChannel":0,"txChannel":1,"speed":"40 kbps","schemeState":3,"tries":3,"lastFailPath":[0,0],"value":[0,19,23,12,143,1,2,4,129,6,74,44,3,70,5,0,5]},{"updateTime":1507628687,"delivered":false,"deliveryTime":130,"packetLength":15,"nodeId":23,"returnRSSI":[127],"hops":[],"returnChannel":0,"txChannel":1,"speed":"40 kbps","schemeState":3,"tries":3,"lastFailPath":[0,0],"value":[0,19,23,12,143,1,2,4,129,6,74,44,3,70,5,0,5]},{"updateTime":1507628696,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,176,0,0,0,0,0,0]},{"updateTime":1507628708,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,187,0,0,0,0,0,0]},{"updateTime":1507628713,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,173,0,0,0,0,0,0]},{"updateTime":1507628729,"nodeId":124,"dstNodeId":1,"RSSI":193,"frameType":"singlecast","value":[50,2,33,100,0,1,42,47,0,120,0,1,42,34]},{"updateTime":1507628731,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,183,0,0,0,0,0,0]},{"updateTime":1507628759,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,231,0,0,0,0,0,0]},{"updateTime":1507628768,"nodeId":104,"dstNodeId":1,"RSSI":201,"frameType":"singlecast","value":[50,2,33,52,0,0,4,181,0,0,0,0,0,0]},{"updateTime":1507628771,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,184,0,0,0,0,0,0]},{"updateTime":1507628789,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,181,0,0,0,0,0,0]},{"updateTime":1507628801,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,5,225,0,0,0,0,0,0]},{"updateTime":1507628830,"nodeId":22,"dstNodeId":1,"RSSI":202,"frameType":"singlecast","value":[143,1,6,3,128,3,72,6,67,3,1,66,2,38,4,70,8,0,127,2,129,5,2,70,4,2,132,7]},{"updateTime":1507628830,"delivered":false,"deliveryTime":160,"packetLength":15,"nodeId":22,"returnRSSI":[127],"hops":[],"returnChannel":0,"txChannel":1,"speed":"40 kbps","schemeState":3,"tries":3,"lastFailPath":[0,0],"value":[0,19,22,12,143,1,2,4,129,6,74,47,3,70,5,0,5]},{"updateTime":1507628830,"delivered":false,"deliveryTime":160,"packetLength":15,"nodeId":22,"returnRSSI":[127],"hops":[],"returnChannel":0,"txChannel":1,"speed":"40 kbps","schemeState":3,"tries":3,"lastFailPath":[0,0],"value":[0,19,22,12,143,1,2,4,129,6,74,47,3,70,5,0,5]},{"updateTime":1507628838,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,219,0,0,0,0,0,0]},{"updateTime":1507628840,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,208,0,0,0,0,0,0]},{"updateTime":1507628849,"nodeId":124,"dstNodeId":1,"RSSI":193,"frameType":"singlecast","value":[50,2,33,100,0,1,42,59,0,120,0,1,42,47]},{"updateTime":1507628858,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,210,0,0,0,0,0,0]},{"updateTime":1507628871,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,199,0,0,0,0,0,0]},{"updateTime":1507628873,"nodeId":104,"dstNodeId":1,"RSSI":199,"frameType":"singlecast","value":[50,2,33,52,0,0,4,193,0,0,0,0,0,0]},{"updateTime":1507628874,"nodeId":16,"dstNodeId":1,"RSSI":196,"frameType":"singlecast","value":[143,1,6,3,128,3,70,6,67,3,1,66,2,188,4,70,8,0,127,2,129,5,2,70,4,2,132,7]},{"updateTime":1507628874,"delivered":false,"deliveryTime":160,"packetLength":15,"nodeId":16,"returnRSSI":[127],"hops":[],"returnChannel":0,"txChannel":1,"speed":"40 kbps","schemeState":3,"tries":3,"lastFailPath":[0,0],"value":[0,19,16,12,143,1,2,4,129,6,74,47,3,70,5,0,5]},{"updateTime":1507628874,"delivered":false,"deliveryTime":160,"packetLength":15,"nodeId":16,"returnRSSI":[127],"hops":[],"returnChannel":0,"txChannel":1,"speed":"40 kbps","schemeState":3,"tries":3,"lastFailPath":[0,0],"value":[0,19,16,12,143,1,2,4,129,6,74,47,3,70,5,0,5]},{"updateTime":1507628882,"nodeId":24,"dstNodeId":1,"RSSI":182,"frameType":"singlecast","value":[143,1,6,3,128,3,72,6,67,3,1,66,9,246,4,70,8,0,127,2,129,5,2,70,4,2,132,7]}]
klaasjoerg
Re: v2.3.6 is out!
Post by klaasjoerg »
Apart from my hue vdev problem as written above, there also seem to be similar problems with logical-rule app and inactivity-app... So I switched back to 2.3.5. for now.
ghrayfahx
Re: v2.3.6 is out!
Post by ghrayfahx »
How do we get these updates if we’re running on a My Cloud? We’re several updates behind at this point.
Re: v2.3.6 is out!
@ghrayfahx: MyCloud version is not approved by WD yet. As I know, it was delivered to WD last week.
@micky1500: seems Route Map feature have a problem with RSSI values. We will check it and make a small patch to fix this.
