Razberry 2 and Wheezy
ScotsDon
Post by ScotsDon »
Several queries:
1) The "ZWay Essentials" manual says "You already have a working Linux (Jessie) running", implying maybe Jesse only. Does anyone know if the Razberry 2 runs under Wheezy?
2) I am trying to upgrade from Razberry (1) to Razberry 2, on a RPi model 1 B, running Wheezy. I am trying to upgrade by saving a Backup of my settings for my Razberry 1 using Expert UI, power off the Pi, change the boards over, power back on and then doing a Restore (from the Expert UI). If I leave the "Restore Network Topology" box unticked, the restore runs OK but I see no devices. If I tick this box, it says restore failed. Actually I don't really know whether to tick the box or not?? If it should be ticked, why is it failing?
3) I ran the command:
wget -q -O - httpp://razberry.z-wave.me/install | sudo bash
to upgrade my z-wave stuff, but I noticed afterwards that the version was v2.0.1, which is 3 years old. I did this with the Raz 1 attached to the Pi. Why would I not get a newer version? How do I get the latest version?
ScotsDon
Re: Razberry 2 and Wheezy
Post by ScotsDon »
Edit: In Item (3) above, I found I had a typo in my wget command. I had put an exclamation mark in (!) instead of the vertical line |. The upgrade now ran and gave me v2.3.7. Ignore Item (3).
ScotsDon
Post by ScotsDon »
Edit 2: Using v2.3.7, the problems seem to have gone away. I needed to have the "Restore Network Topology" box ticked to restore the devices. Following a quick test of one device, I was able to switch it on and off via the Smartphone app. I will let my RPi run and see how it gets on. I don't use manual commands normally.
Sorry for the 'false alarm'!
