Z-UNO used on Axial server
Posted: 29 Jan 2019 11:40
I was having difficulty including the z-UNO with Axial server. As a new person to the Z-Uno and Z-Wave in general, I think the Z-UNO documentation could be a little more explanatory. Questions and observations below:-
1 The Arduino IDE seems to have to be 1.6.5, is this the case, if so will an update be available to run it on current Arduino IDE's.?
2 Whilst I guess its logical now, I found the parameters selected in the Tools section of Arduimo for the Z-UNO only take effect in the Z-UNO afer a new Burn Bootloader command is performed. I suspect that the main issue in not being able to include, was that the Z-UNO by default is probably set to the Russian frequency.
3 Can you explain the difference between No security, S0 and S2.
4 Can you explain the function of Erase NVM.
5 Is the logging feature by the UART0 via the Arduino Serial monitor?
6 If logging by radio please can you explain how this operates?
Now I have the Z-UNO included I find it a great device.
