Z-Way v3.0.0 Release
Re: Z-Way v3.0.0 Release
Please clear browser cache and cookies. This is required on new version installation
fez
Post by fez »
That was it: clear browser cache and cookies.
It works.
I cleared the cache in my previous trials, but not the cookies.
Thanks for the clarification.
tma
Post by tma »
I have a Raspberry 3B booting Raspbian Jessie from an SSD disk.
Booting from USB does not work correctly in Stretch and Buster versions.
Is it possible to upgrade to version 3.0.0 from Raspbian Jessie without updating OS?
- I have read that the problem is the lack of openssl 1.0.2 -> https://forum.z-wave.me/viewtopic.php?f ... 604#p83609
- And also how it can be installed on Jessie https://raspberrypi.stackexchange.com/q ... -pi3/67045
So is it possible?
You can use the .tgz tar-ball and make sure all needed libraries are found
micky1500
Post by micky1500 »
Log file is getting large (348 MB) since I reinstalled a new build with 3.0.0
A new PI3+ with Stretch and 3.0.0
\var\log\z-way-server.log is now 348,091 KB
The whole 2 weeks of logs since I upgraded.
Do I need to install something like log-rotate ?
I didn't need to do this on 2.3.8
Raspi 4(Buster), Zwave Version 3.0.6 x It's not my fault... I am not z-way team, just a user of a great system.
Good point! we need to set up log-rotate in next version. Thanks for the hind. I think we never had it enabled for Z-Way on Raspbian
nkraus
Post by nkraus »
When I try to install it always says it is already the latest version. But it is version 2.3.8
This is really frustrating
Please follow this guide
https://z-wave.me/z-way-v3-0-0/
nkraus
Post by nkraus »
I had to delete alle entries (z-way-full and z-way-server - not zbw) in /var/lib/dpkg/status and then it worked. Before it always says that the latest version is already installed.
The only problem i have is, that after upgrade to 3.0.0 my UZB-stick is blinking blue all the time. It looks like everything is working fine, but the blinking is absolute disturbing
feuersee
Post by feuersee »
I successfully updated to version 3.0. Software Information Version Number: v3.0.0 Compile ID: 146fa9b44605907737b17032131987cab573da1f Compile Date: 2019-07-18 02:13:01 +0300 UI. The SW Update page shows: The current firmware version is v2.3.8
