Z-Wave.Me future (discussion)
toeb
Re: Z-Wave.Me future (discussion)
Post by toeb »
seattleneil wrote: ↑
06 Apr 2025 22:48
Z-Wave.Me controllers will continue to operate as they do today. Note that Z-Wave.Me controllers can be used with Z-Way software or they can be used with other Z-Wave software, such as zwave-js-ui, as used in Home Assistant. Transitioning from Z-Way to zwave-js-ui is straightforward - copy the S0 and S2 keys from Z-Way to zwave-js-ui and configure device names to have friendly names.
I' would like to try this... where would i find the S0 and S2 z-way keys? My current setup is using a RaZberry 7 pro
TIA
toeb
seattleneil
Post by seattleneil »
S2 keys are stored in the directory /opt/z-way-server/config/zddx in the file that ends in -DevicesData.xml. The file name begins with 8 hex digits that are unique to each network - these digits are the Z-Wave network ID (in hex).
This command should print out the keys:
grep '^    <data name="S2.*binary' /opt/z-way-server/config/zddx/*-DevicesData.xml
toeb
Post by toeb »
28 Sep 2025 18:58
Thanks!
If i run this command with "S0" instead of S2 i should get the legacy keys, right? If I do not find anything for S0, does it simply mean i don't have legacy devices in my network or do I need to search for another keyword?
Greetings
seattleneil
Substituting "S0" for "S2" will not work.
Use this command to get the S0 key (called networkKey):
grep 'networkKey.*binary' /opt/z-way-server/config/zddx/*-DevicesData.xml
toeb
Post by toeb »
29 Sep 2025 00:11
Thanks, found it :)
element
Post by element »
To avoid throwing away broken and flashing red electronic boards, I bought a Silicon Labs programmer. I was hoping to transfer the memory from a working board to a non-working one. Unfortunately, it turns out the boards have a debug access lock installed, which, if removed, erases the memory, meaning my idea is useless.
And now for the interesting part.
I could unlock debug access from the working board without any problems. However, I couldn't unlock debug access from the non-working board. I had to use the "Recover bricked device" option. Flashing new firmware onto two of my Z-Uno2 boards resulted in a "bricked device," and the only solution was to flash it through the programmer.
Can PoltoS share a file I can flash through the programmer to restore the Z-Uno2 board?
Sharing the compiled file, so without disclosing the source, I don't think it would be a big deal.
PS:
I described the problem of boards that are completely non-functional with the new firmware in these threads:
1.https://forum.z-wave.me/viewtopic.php?f=3427&t=36152
2.https://forum.z-wave.me/viewtopic.php?f=3427&t=36153
topcatsss
Post by topcatsss »
@PoltoS what other software works with the razberry board?
luhrern
Post by luhrern »
Does Trident IOT have an alternative software that I can change to ?
lanbrown
Post by lanbrown »
luhrern wrote: ↑
30 Dec 2025 00:27
They still have Z-Way; there is no successor to Z-Way as they released 5.x.
No one here is going to be able to provide any suggestions as well, your question provides too little information. Could you switch to another home automation platform? Sure, what is a right fit to you only you would know. There are many things that can run on a Pi, other Linux systems and can use a Razberry board. If you use Windows with a UZB, then it is a different story. Back to your question provides too little information.
ScotsDon
Post by ScotsDon »
Hi all. PoltoS may remember me from debugging a rather odd fault that occurred at 3 a.m. only!
My query is as follows. Over the past dozen years I have written a lot of Python software for my Raspberrry Pi and Razberry setup (now Razberry 7). I did this directly without using things like Home Assistant. It was a hobby created originally to control my underfloor heating on sunny days (using a Met Office forecast download) in spring/autumn when the house gets a lot of solar gain, and then it expanded to control hot water, heating on another floor using a PIR, the ventilation system depending on the weather forecast, blinds raising/lowering (at sunset) etc. So there is a lot of investment in my time.
Z-Way is installed on the Pi. My software uses HTTP calls to initiate actions, such as:
responseAction = urllib.request.urlopen('http://localhost:8083/ZWaveAPI/Run/devices[' + Device + '].instances[' + DevInst+ '].commandClasses.SwitchBinary.Set(' + DevState + ')')
where the " ' + Device + ' " etc become the values to be used.
If I continue to use Z-Way v4.1.4 then presumably everything will continue to work. But in due course it seems likely that something will change.
  • Will I need to do a complete rewrite and use something like Home Assistant. I rather dread that.
  • Will I be able to use the same software with whatever Trident offer?
  • I use both the Smarthome and the Expert UI quite a bit, for testing switch operations, viewing sensor information, viewing Timing info, doing system Reorganisation, updating or viewing Neighbours, viewing Route information and so on. Will this be available from Trident?
Of course, this depends on my Razberry staying alive, and if not, an alternative board appearing (I note there seem to be no Razberry boards for sale now). USB dongles are a possibility I assume.
Any comments?
