Z-Connector with DSL router
pierrot24
Post by pierrot24 »
Is it possible to install the software Z-Connector into a DSL router, in a way to not use a PC..?
If it's possible, how do you do...?
Pierrot
Yes, it is! For now we have recipes for OpenWRT DSL routers...
... and their clones: DD-WRT and Oleg's firmware. The process of installations is described in two posts:OpenWRT & DD-WRTOleg's firmwareSince Z-Connector comes in open source, you can also compile Z-Connector for any other DSL router if you know how to build applications your model.We also have a solution for FritzBox, but it is not published yet.Don't forget to share your success stories!
yannick
When will the Fritz!Box
Post by yannick »
When will the Fritz!Box solution be published?
christian
Fritzbox
Post by christian »
At the moment we are still working on the support for the new fritzboxes 7390 and 7360, It worked quite well on 7170. So I need to ask you for soem patience. AT the moment I cant give you a date yet.
yannick
I'm using a 7170, could you
Post by yannick »
I'm using a 7170, could you send me the one that worked already?
wimric
Fritzbox
Post by wimric »
Can I get your solution for Fritzbox ?
