No login to z-cloud possible any more
Georg Hermann
Post by Georg Hermann »
by sudden (starting last sunday) my gateway (GuruPlug with AEON-Stick 2) can not connect to the z-cloud.
The loop is just established for a few seconds.
There is just one message in the browser: "Sorry, server has not completely started yet. Try realoding the interface later."
Is there a server-side problem, or is somthing broken on my side?
I am thankfull for any advise. ;-)
Br
Georg
jussiva
I've same connection problem
Post by jussiva »
I've same connection problem and I guess that problem related to server-side.
pz1
It is live for me
Post by pz1 »
I am still connected since a couple of days, and the Interface screen is active. (I watch on PC, but Z-Agent runs on Syno box)
jussiva
Is there one ore more cloud
Post by jussiva »
Is there one ore more cloud servers for z-wave.me ? Maybe just one is down, and I'm trying to use just that one..
You are not connected
In another post you say that Z-Agent losts conection due to z-agent/stick/raspberry pi problems. Hence, no way to log in to the Z-Cloud panel.
Please fix the problem first and then you will be able to access Z-Cloud
Georg Hermann
I have no "Raspberry Pi"
again, I have the trouble with an GuruPlug. And it worked fine untill Sunday. So there is no "settup-issue".
Br
Georg
jussiva
Hermann, please try to
Post by jussiva »
Hermann, please try to download certification files again. At least it fix all my connection lost problems !
Georg Hermann
done. no effect
I updated the certificates. No effects.
On the server side we see
On the server side we see exactly same as for jussiva:
no responce from the stick.
Please check with debug enabled that packets are sent tot the port. Is there a responce from the stick on your side?
Does it work on a PC?
We have not updated Z-Cloud since November 19. The only way to break something is the automatic installation of critical updates done by Ubuntu server. Last down time was due to such an update ;( We are checking if there were any changes.
