I have been getting this error since this morning
Failed to perform handshake: (null)
Can anyone explain what it means?
I have tried power cycling the RPI but nothing
I have just noticed that when
I have just noticed that when i try and re download the certificates the zip contains
ff
pyzw_stdout.log
ssl_py.old
What would be causing this?
ff
pyzw_stdout.log
ssl_py.old
We are fixing this problem.
We are fixing this problem. Was on server side.
Thanks PoltoS, looks like it
Thanks PoltoS, looks like it is connecting now but devices do not update statuses or respond to outputs
Everything was restarted, so
Everything was restarted, so should work. please check
PoltoS, no good mate, still
PoltoS, no good mate, still not updating....should i redownload my certificates?
Which device does not update
Which device does not update it's status? Should it? Are you sure the device is associated with Z-Cloud node id?
homeauto@mfhome.co.uk
kopite - did you get your
kopite - did you get your certificates? those files you saw ff, pzyw etc were errors I think. The cert files usually look like filename(s).cert
same problem today
I'm trying to connect for the first time whitout success. I followed the right way but have the message "Failed to perform handshake: (null)". I noticed that if you download certs today, they are not the good one (pyzw_stdout.log,...). I did not download these and got the good one from a previous download.
Thanks for your support
