What do echo -ne "\x01\x03\x00\x08\xf4" > /dev/ttyAMA0
domatech
Post by domatech »
Hello all,
My raspberry can't stay alive more than a week, after a week of good services, the daemon could not start he says : "Device not compatible... terminating".
The only way i found to resolve the problem is : echo -ne "\x01\x03\x00\x08\xf4" > /dev/ttyAMA0
But to be honesty i don't know what exactly do this command, what is the risk to use it ? ( loose configuration files, destroy drivers, make explode fort knox ? )
Anyone can explain me ?
Best regards :)
pz1
Re: What do echo -ne "\x01\x03\x00\x08\xf4" > /dev/ttyAMA0
Post by pz1 »
Which version are you using? There have been memory leaks in previous versions, which may explain your problems. This leaks have been solved in 1.7.1-rc2. Those fixes are now in the official 1.7.1 release of yesterday.
I suggest to update and watch that for an other week
domatech
Post by domatech »
Great thanks, i try this right now
pofs
Post by pofs »
Looks like a broken RaZberry to me.
Check the manufacture date printed on board. If it is middle of April, ask your supplier for replacement.
This command reboots the chip on the board. But this indeed looks like a semi-dead board
domatech
Post by domatech »
And what if i put echo -ne "\x01\x03\x00\x08\xf4" in a daily crontab ?
nothing critical unless it goes in the middle of a command or between request and response from Z-Way. In that case Z-Way can freak out. But should still work
domatech
Post by domatech »
I already stop / start z-way server at 4:00, so i can do the magic command at this moment so i think i can't have problems, i try like that.
Thanks for all the help :)
This might be helpful for others with same problem with RaZberries from April 2014: viewtopic.php?f=3422&t=20389&p=51857#p51857
