Hi, I've just buy a z-box,
I successfully access to http://[IP]:8084 and http://[IP]:8083, and also add a zwave module to the box but :
When I try to do an update, seems that nothing is done
The current firmware version is v1.3.1 2013-05-19 (seems a little bit old)
I'm also try to login on the z-box using ssh (user:root pwd:z-box) but I always get "acces denied"!
Can anyone know if there is new firmware for the z-box ? and how to do the update ?
Regards
Ps : Sorry is my english is not very good, I'm a french guy
Other Informations :
Role in Network
Node Id: 1
Home Id: 0xcf78098a
Primary Role: yes
Primary Capability: yes
SUC/SIS in network: No SUC/SIS present
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 2 / 3
Z-Wave Chip: ZW0301
Firmware
SDK Version: 4.54 pl1
Serial API Version: 04.02
Z-Way Version
Revision Version: v1.3-rc3-9-gec23927
Revision ID: ec239270dd5126f61d3fa83c98710dabf4b52e12
Revision Date: 2013-05-24 23:16:21 +0400
just buy a z-box
Re: just buy a z-box
for z-wave.me support : Z-Way Remote Access ID is 10151
Hi, try this image for z-box:
https://dl.dropboxusercontent.com/u/258 ... 0.2014.img
It's image for 1GB Flash.
Write this image to CF from Z-Box with command like this:
dd if=./z-box_14.10.2014.img of=/dev/sdb bs=8M,
where /dev/sdb it's a CF
SSH Login: root
SSH pass: voyage
SSH Login: root
SSH pass: voyage
hi,
Everything works fine
Just got one error after the first boot when acessing to port 8084: ZBox ID: Err(1.18.3): main.c: 528: The spawned process 'bash:cat /etc/zbw/userid' has exited with code 1 and says: cat: /etc/zbw/userid: No such file or directory
So I go to advanced tab, I do an update, and it's fine
Thank you
Regardss
Thank you
Regardss
Bad news, After few days, the zbox has begin to show signs of weakness, Connection failure, I thought the CF card was corrupted, so i wrote the image again, but the system fails to boot (I tried several times)
I'also try to connect to the serial port to get more information, but terminal screen shows nothing (my parameters : 115200 / 8 / 1 Stop / Parity : None / Flow : XON/XOFF)
can someone help me ?
Regards
Regards
