Consumption buffer per device
GalF
Post by GalF »
I've build an application that connects to the z-wave and fetch
electricity consumption for specified devices,
In the documentation, it is mentioned, that the buffer for
consumption per device is limited my question is - how much it's actually limited?
hous? days? months?
Thanks!
pz1
Re: Consumption buffer per device
Post by pz1 »
Please specify which device, and which documentation. Otherwise it is hard to tell
GalF
Post by GalF »
The documentation I talk about is in here:
http://razberry.z-wave.me/docs/zwayDev.pdf
the device is razberry-pie with z-wave chip attached to it.
I comuunicate with the json api as you can guess from the reference
thanks
pz1
Post by pz1 »
  1. Did not find anything on consumption and buffer in that document. Could you specify a page or paragraph number
  2. So you want to to log power usage of RaspberryPi + RaZberry chip ???
  3. The developers manual deals with a couple of API's, so it is not obvious what you mean.
GalF
Post by GalF »
a. I use the api from page 29 in the manual I mentioned (every fetch I take only updated data),
but when I try to fetch an update that request more then 6 hours data I get only 6 hours data
b. yes
c. I use the one in page 29 to fetch the data
pz1
Post by pz1 »
Sorry can't find anything about "consumption" in the controller nor devices trees. So I have to leave the answering of this question to the Z-Wave.Me team.
P
