my app stopped working after upgrade
larry
Post by larry »
Yesterday I upgraded to the latest upgrade from August, after this does not http: // RPI: 8084 more. so I do not get downgraded
Razberry app that I received made work no more.
Unable to load data error box
App does not exists or has no valid parameters
How can get downgraded or is it something new site version that makes my app does not work more?
function ElMeterLogging (id, controller) {
    // Call superconstructor first (AutomationModule)
    ElMeterLogging.super_.call(this, id, controller);
inherits(ElMeterLogging, AutomationModule);
_module = ElMeterLogging;
ElMeterLogging.prototype.init = function (config) {
    // Call superclass' init (this will process config argument and so on)
    ElMeterLogging.super_.prototype.init.call(this, config);
    // Remember "this" for detached callbacks (such as event listener callbacks)
    var self = this;
    // Here we assume that period is factor of minute and less than hour, or factor of hours and less than day, or factor of days
    var p = Math.round(this.config.period);
    var m = (p < 60) ? [0, 59, p] : 0;
    var h = p >= 24*60 ? 0 : (p/60 >=1 ? [0, 59, Math.round(p/60)] : null);
    var wd = p/24/60 >=1 ? [0, 6, Math.round(p/24/60)] : null;
    if (this.config.deviceid !== 0 )
       var deviceid = parseInt(this.config.deviceid,10);
    else {
	console.log ("ERROR: ElMeterLogging Device Id not correct");
    if (this.config.devinstance >= 0 )
       var devinstance = parseInt(this.config.devinstance,10);
    else {
        console.log ("ERROR: ElMeterLogging Device Instance not correct");
    if (this.config.devcommandclass !== 0 )
       var devcommandclass = parseInt(this.config.devcommandclass,10);
    else {
    this.controller.emit("cron.addTask", "ElMeterLogging.poll", {
        minute: m,
        hour: h,
        weekDay: wd,
        day: null,
        month: null
    this.onPoll = function () {
        //CurrentDataGet(1) gets only first parameter. This should be bitmask, see table at end of PDF,
	// but it doesn't works. To get all params, use CurrentDataGet();
	zway.devices[deviceid].instances[devinstance].commandClasses[devcommandclass].CurrentDataGet();
    // Setup metric update event listener
    this.controller.on('ElMeterLogging.poll', this.onPoll);
    this.bindFunc = function(zwayName) {
	if (zwayName != "zway") return; // you want to bind to default zway instance
	var devices = global.ZWave[zwayName].zway.devices;
	devices[deviceid].instances[devinstance].commandClasses[devcommandclass].data[1].val.bind(function() {
//		debugPrint("Power " + this.value + "  " +this.updateTime);
 		  system("php /opt/z-way-server/automation/modules/ElMeterLogging/savedb.php " + this.value + " " + this.updateTime);
	//Instantaneous Primary Active Power (kW) ,Current power consumption.
	devices[deviceid].instances[devinstance].commandClasses[devcommandclass].data[5].val.bind(function() {
//		 debugPrint("Instant " + this.value + "  " +this.updateTime);
                  system("php /opt/z-way-server/automation/modules/ElMeterLogging/savedb.php " + this.value + " " + this.updateTime + " instantkw");
     global.controller.on("ZWave.register", this.bindFunc);
ElMeterLogging.prototype.stop = function () {
    SensorValueLogging.super_.prototype.stop.call(this);
    this.controller.off('ElMeterLogging.poll', this.onPoll);
pz1
Re: my app stopped working after upgrade
Post by pz1 »
larry wrote: How can get downgraded or is it something new site version that makes my app does not work more?
In a SSH session to your Pi change the name
/opt/z-way-server
to something like
/opt/z-way-server_corrupt
Under /opt you should have one or more folders named something like z-way-server_2015-08-28-14-32-07
choose the one with the time of your update, and rename that to
/opt/z-way-server
Then reboot. I am not sure if that brings your 8084 back since that interface resides in /var/webif
Please check
http://razberry.z-wave.me/index.php?id=24
I suggest to try a clean new install to check if it works.
