Error: Bad data - communication failed
fabioyy
Post by fabioyy »
Hi
My razberry is not working anymore
i get:
[2015-11-14 18:53:30.719] [D] [zway] SENT ACK
[2015-11-14 18:53:30.719] [D] [zway] SETDATA devices.1.data.isFailed = False
[2015-11-14 18:53:30.719] [zway] Job 0x62 (Check if node is failed): Node 1 is operating
[2015-11-14 18:53:30.719] [D] [zway] Job 0x62 (Check if node is failed): success
[2015-11-14 18:53:30.719] [zway] Removing job: Check if node is failed
[2015-11-14 18:53:30.720] [D] [zway] SENDING: ( 01 04 00 62 02 9B )
[2015-11-14 18:53:30.727] [D] [zway] Worker thread exit point
[2015-11-14 18:53:30.727] [D] [zway] Worker thread successfully finished
[2015-11-14 18:53:30.728] [zway] Saving configuration data to config/zddx/ffffffff-DevicesData.xml
[2015-11-14 18:53:32.057] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
The red light led is on
Any tips?
Re: Error: Bad data - communication failed
on shiny or dimmed
Try to powercycle it (full RPi)
fabioyy
Post by fabioyy »
Nothing, left for 2 hours off and still the red light persist
Also there is 232 devices on log ( i removed and reinstall z-wave to be sure that was nothing in the software )
[2015-11-14 22:57:52.695] [D] [zway] SETDATA devices.231.data.basicType = 0 (0x00000000)
[2015-11-14 22:57:52.696] [D] [zway] SETDATA devices.231.data.genericType = 0 (0x00000000)
[2015-11-14 22:57:52.696] [D] [zway] SETDATA devices.231.data.specificType = 0 (0x00000000)
[2015-11-14 22:57:52.696] [D] [zway] SETDATA devices.231.data.infoProtocolSpecific = 0 (0x00000000)
[2015-11-14 22:57:52.696] [D] [zway] SETDATA devices.231.data.deviceTypeString = ""
[2015-11-14 22:57:52.697] [D] [zway] SETDATA devices.231.data.isVirtual = False
[2015-11-14 22:57:52.697] [D] [zway] SETDATA devices.231.data.isListening = True
[2015-11-14 22:57:52.697] [D] [zway] SETDATA devices.231.data.isRouting = False
[2015-11-14 22:57:52.697] [D] [zway] SETDATA devices.231.data.isAwake = False
[2015-11-14 22:57:52.697] [D] [zway] SETDATA devices.231.data.optional = False
[2015-11-14 22:57:52.697] [D] [zway] SETDATA devices.231.data.isFailed = False
[2015-11-14 22:57:52.697] [D] [zway] SETDATA devices.231.data.beam = False
[2015-11-14 22:57:52.698] [D] [zway] SETDATA devices.231.data.sensor250 = False
[2015-11-14 22:57:52.698] [D] [zway] SETDATA devices.231.data.sensor1000 = False
[2015-11-14 22:57:52.698] [D] [zway] SETDATA devices.231.data.manufacturerId = 0 (0x00000000)
[2015-11-14 22:57:52.698] [D] [zway] SETDATA devices.231.data.vendorString = ""
[2015-11-14 22:57:52.698] [D] [zway] SETDATA devices.231.data.manufacturerProductType = 0 (0x00000000)
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.manufacturerProductId = 0 (0x00000000)
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.ZWLib = 0 (0x00000000)
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.ZWProtocolMajor = 0 (0x00000000)
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.ZWProtocolMinor = 0 (0x00000000)
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.SDK = ""
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.applicationMajor = 0 (0x00000000)
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.applicationMinor = 0 (0x00000000)
[2015-11-14 22:57:52.699] [D] [zway] SETDATA devices.231.data.ZDDXMLFile = ""
[2015-11-14 22:57:52.700] [D] [zway] SETDATA devices.231.data.lastReceived = 0 (0x00000000)
[2015-11-14 22:57:52.700] [D] [zway] SETDATA devices.231.data.keepAwake = False
[2015-11-14 22:57:52.700] [D] [zway] SETDATA devices.231.data.countSuccess = 0 (0x00000000)
[2015-11-14 22:57:52.700] [D] [zway] SETDATA devices.231.data.countFailed = 0 (0x00000000)
[2015-11-14 22:57:52.700] [D] [zway] SETDATA devices.231.data.queueLength = 0 (0x00000000)
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.data.givenName = ""
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.instances.0.data.dynamic = False
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.instances.0.data.genericType = 0 (0x00000000)
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.instances.0.data.specificType = 0 (0x00000000)
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data = Empty
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.supported = Empty
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.supported = True
[2015-11-14 22:57:52.701] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.version = Empty
[2015-11-14 22:57:52.702] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2015-11-14 22:57:52.702] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.security = Empty
[2015-11-14 22:57:52.702] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.security = False
[2015-11-14 22:57:52.702] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.interviewDone = Empty
[2015-11-14 22:57:52.702] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.interviewCounter = Empty
[2015-11-14 22:57:52.702] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.interviewDone = False
[2015-11-14 22:57:52.702] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2015-11-14 22:57:52.703] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.level = Empty
[2015-11-14 22:57:52.703] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.supported = True
[2015-11-14 22:57:52.703] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2015-11-14 22:57:52.703] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.security = False
[2015-11-14 22:57:52.703] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.interviewDone = False
[2015-11-14 22:57:52.704] [D] [zway] SETDATA devices.231.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2015-11-14 22:57:52.704] [D] [zway] SETDATA devices.232.data.basicType = 0 (0x00000000)
[2015-11-14 22:57:52.704] [D] [zway] SETDATA devices.232.data.genericType = 0 (0x00000000)
[2015-11-14 22:57:52.704] [D] [zway] SETDATA devices.232.data.specificType = 0 (0x00000000)
[2015-11-14 22:57:52.704] [D] [zway] SETDATA devices.232.data.infoProtocolSpecific = 0 (0x00000000)
[2015-11-14 22:57:52.704] [D] [zway] SETDATA devices.232.data.deviceTypeString = ""
[2015-11-14 22:57:52.705] [D] [zway] SETDATA devices.232.data.isVirtual = False
[2015-11-14 22:57:52.705] [D] [zway] SETDATA devices.232.data.isListening = True
[2015-11-14 22:57:52.705] [D] [zway] SETDATA devices.232.data.isRouting = False
[2015-11-14 22:57:52.705] [D] [zway] SETDATA devices.232.data.isAwake = False
[2015-11-14 22:57:52.706] [D] [zway] SETDATA devices.232.data.optional = False
[2015-11-14 22:57:52.706] [D] [zway] SETDATA devices.232.data.isFailed = False
[2015-11-14 22:57:52.706] [D] [zway] SETDATA devices.232.data.beam = False
[2015-11-14 22:57:52.706] [D] [zway] SETDATA devices.232.data.sensor250 = False
[2015-11-14 22:57:52.706] [D] [zway] SETDATA devices.232.data.sensor1000 = False
[2015-11-14 22:57:52.706] [D] [zway] SETDATA devices.232.data.manufacturerId = 0 (0x00000000)
[2015-11-14 22:57:52.707] [D] [zway] SETDATA devices.232.data.vendorString = ""
[2015-11-14 22:57:52.707] [D] [zway] SETDATA devices.232.data.manufacturerProductType = 0 (0x00000000)
[2015-11-14 22:57:52.707] [D] [zway] SETDATA devices.232.data.manufacturerProductId = 0 (0x00000000)
[2015-11-14 22:57:52.707] [D] [zway] SETDATA devices.232.data.ZWLib = 0 (0x00000000)
[2015-11-14 22:57:52.707] [D] [zway] SETDATA devices.232.data.ZWProtocolMajor = 0 (0x00000000)
[2015-11-14 22:57:52.707] [D] [zway] SETDATA devices.232.data.ZWProtocolMinor = 0 (0x00000000)
[2015-11-14 22:57:52.707] [D] [zway] SETDATA devices.232.data.SDK = ""
[2015-11-14 22:57:52.708] [D] [zway] SETDATA devices.232.data.applicationMajor = 0 (0x00000000)
[2015-11-14 22:57:52.708] [D] [zway] SETDATA devices.232.data.applicationMinor = 0 (0x00000000)
[2015-11-14 22:57:52.708] [D] [zway] SETDATA devices.232.data.ZDDXMLFile = ""
[2015-11-14 22:57:52.708] [D] [zway] SETDATA devices.232.data.lastReceived = 0 (0x00000000)
[2015-11-14 22:57:52.708] [D] [zway] SETDATA devices.232.data.keepAwake = False
[2015-11-14 22:57:52.709] [D] [zway] SETDATA devices.232.data.countSuccess = 0 (0x00000000)
[2015-11-14 22:57:52.709] [D] [zway] SETDATA devices.232.data.countFailed = 0 (0x00000000)
[2015-11-14 22:57:52.709] [D] [zway] SETDATA devices.232.data.queueLength = 0 (0x00000000)
[2015-11-14 22:57:52.709] [D] [zway] SETDATA devices.232.data.givenName = ""
[2015-11-14 22:57:52.709] [D] [zway] SETDATA devices.232.instances.0.data.dynamic = False
[2015-11-14 22:57:52.709] [D] [zway] SETDATA devices.232.instances.0.data.genericType = 0 (0x00000000)
[2015-11-14 22:57:52.709] [D] [zway] SETDATA devices.232.instances.0.data.specificType = 0 (0x00000000)
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data = Empty
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.supported = Empty
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.supported = True
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.version = Empty
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.security = Empty
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.security = False
[2015-11-14 22:57:52.710] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.interviewDone = Empty
[2015-11-14 22:57:52.711] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.interviewCounter = Empty
[2015-11-14 22:57:52.711] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.interviewDone = False
[2015-11-14 22:57:52.711] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2015-11-14 22:57:52.711] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.level = Empty
[2015-11-14 22:57:52.711] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.supported = True
[2015-11-14 22:57:52.712] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2015-11-14 22:57:52.712] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.security = False
[2015-11-14 22:57:52.712] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.interviewDone = False
[2015-11-14 22:57:52.712] [D] [zway] SETDATA devices.232.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2015-11-14 22:57:52.803] [D] [zway] Job 0x02 (Get initial data about network devices): success
[2015-11-14 22:57:52.861] [C] [zway] No controller device found
[2015-11-14 22:57:52.861] [zway] Removing job: Get initial data about network devices
[2015-11-14 22:57:52.862] [D] [zway] SENDING: ( 01 04 00 62 01 98 )
[2015-11-14 22:57:52.864] [D] [zway] RECEIVED ACK
[2015-11-14 22:57:52.864] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2015-11-14 22:57:52.864] [D] [zway] SENT ACK
[2015-11-14 22:57:52.865] [D] [zway] SETDATA devices.1.data.isFailed = False
[2015-11-14 22:57:52.865] [zway] Job 0x62 (Check if node is failed): Node 1 is operating
[2015-11-14 22:57:52.865] [D] [zway] Job 0x62 (Check if node is failed): success
[2015-11-14 22:57:52.865] [zway] Removing job: Check if node is failed
[2015-11-14 22:57:52.866] [D] [zway] SENDING: ( 01 04 00 62 02 9B )
[2015-11-14 22:57:52.873] [D] [zway] Worker thread exit point
[2015-11-14 22:57:52.873] [D] [zway] Worker thread successfully finished
[2015-11-14 22:57:52.875] [zway] Saving configuration data to config/zddx/ffffffff-DevicesData.xml
[2015-11-14 22:57:54.242] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
I have tried the echo -ne "x01x04x00x42x01xB8" > /dev/ttyAMA0 command, ( and still nothing )
fabioyy
Post by fabioyy »
Ok, i'm giving up on razberry.
We have started a small automation company, but after 4 dead devices ( of 7 ) ( 2 dead by the frequency change bug, 1 dead and overheating, and this one. ) i just can't use such unstable device on my customers.
i'm switching to aeron and openzwave.
